hi chrissyboy
svcd2dvd 2.5 installed ok but when i go to register online it keeps coming up with ****VERY IMPORTANT**** PLEASE EDIT BOX 2(NAME)TO ANYTHING OVER 8 CHARACTERS i have done this but it will not register online
cheers bighun
Results 1 to 25 of 25
Ok. Is this with Vista? Can you "right click"->Run as administrator on the SVCD2DVD.exe to complete the registration process?
Hi Chrissyboy,
Running vista ultimate, had same issue registering. Right clicked svcd2dvd.exe and it ran and registered OK.
Ran into this issue, could not add two assests to the same VTS , would not build it into the menu. Forced me to make 2 vts,s. Other than that seems to working OK.
Noticed that there is no option now to burn with Nero, only img and copytodvd, will that be the case from now on ? Did use IMG and worked flawlessy, however could not figure out how to turn off the verify option in IMG even in the IMG option settings. -
If you want separate menu buttons for the assets, you have to put them in separate VTS's, it's always been that way.
I believe that Chrissyboy does intend the new burning options to continue as they are now (no Nero). IMGBurn is a much better option anyway. Ah...I found it here:
https://forum.videohelp.com/viewtopic.php?p=1620299#1620299Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Thanks for the input guys. I should have been more specific on the IMG thing. The first run of Svcd2dvd with autoburn it did try to verify. I stopped it and it complained . Then ran IMG and did untick the verify button, but on the next dvd I made with svc2dvd it still wanted to verify. Thats when I thought the verify mode option was broke
Made another test DVD to today and now all is well verify did not run. Go figure; guess IMG just needed to get reset or something
hi,
i installed 2.5 without problems one XP, and i am very impressed by the speed andvantage of about 30%
on my Core 2 Duo
I seen to be having install problem with vista and 2.0, it did work with vista at one point, but something odd has happend, and now with 2.5 beta, its still not working.. here is my log
************** Exception Text **************
System.ArgumentException: Parameter is not valid.
at System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format)
at System.Drawing.Bitmap..ctor(Int32 width, Int32 height)
at x3284ccece41ee22b.xddb8d1ea6c9958c7.xbce0680d1ae3e 0bc(Image x7b28e8a789372508, Int32 xdc1bf80853046136, Int32 xb0f146032f47c24e)
at x3284ccece41ee22b.xddb8d1ea6c9958c7.xa44f52b503763 8be()
at x3284ccece41ee22b.xddb8d1ea6c9958c7.x20aee28197748 0cf()
at x3284ccece41ee22b.xddb8d1ea6c9958c7..ctor()
at x3284ccece41ee22b.x210ff09a2516b1a7.xc456b78441ff1 c49()
at x3284ccece41ee22b.x210ff09a2516b1a7.x07267fbbae07d a13(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Form.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallba ckDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallba ckHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Objec t userData)
at System.Runtime.CompilerServices.RuntimeHelpers.Exe cuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(Exec utionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallba ck(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallba cks()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SVCD2DVD
Assembly Version: 2.5.2668.32237
Win32 Version: 2.5.2668.32237
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/%APPNAME%.EXE
DevComponents.DotNetBar2
Assembly Version: 6.6.0.0
Win32 Version: 6.6.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/DevComponents.DotNetBar2.DLL
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Deployment
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
Accessibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/Interop.QuartzTypeLib.DLL
System.Design
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box. -
Are you running the program as administrator? Did you install in a folder other than "Program Files"? Both of these are recommended on Vista.
Dwight
- Herm Albright
Also - it looks like your .Net installation is corrupt. Can you reinstall .net 2?
I installed both my 2.0 and 2.5 in program files, also I re-installed .Net 1.1 few times, I can't seem to re-install Net 2.0, says its already installed and I can't find a uninstall for Net 2.0, maybe its a vista thing.
I got 2.5 to finally work, I went to the options and kept hitting continue on the error screen when I changed one of the options and now its working.. very odd, I'm sure its not 100% -
It is recommended that you NOT install SVCD2DVD to the "program files" directory.
Check Microsoft Knowledgebase for info on reinstalling .Net 2.0.Dwight
- Herm Albright
Hi
I am trying out the 2.5 Beta and it seems to process properly and quickly however I do have one problem.
System Details
Core 2 Duo 6600
2Gb RAM
Nvidia Geforce 7950GT
Vista Home Premium
I have installed the software under c:\software not in program files as suggested and I run it as administrator
When I try to save the settings it always closes down svcd2dvd. Has anyone got any suggestions?
Steve -
Do you get any error message? Are there any other details that might help us (what changes are you attempting to make)?
Dwight
- Herm Albright
I can reproduce the problem every time by changing the initial DVD output folder and then pressing apply setting to this project only. No error messages just the Microsoft windows popup box that says SVCD2DVD has stopped working
a problem caused the program to stop working correctly. Windows will close the program and .....
Steve -
Does it happen if you open the settings and click "Appliy settings to this project only", without actually changeing any settings?
Just FYI: I cannot reproduce this error in XP.
What is the folder path you are attempting to change to (just wondering if it may be a character issue)?Dwight
- Herm Albright
I have tried several
d:\SVCDOUTPUT to d:\SVCDOUTPUT\test then in case it was anything to do with my D drive I tried
c:\temp\SVCD
Steve -
Hi
May I have the link to the beta version please
reg user
Many thanks
jean
Beta? what is it
By Stephanee in forum ComputerReplies: 3Last Post: 5th Nov 2008, 10:58 -
The FilmMachine v1.6.0.6 Beta is out
By louv68 in forum Latest Video NewsReplies: 0Last Post: 9th Aug 2007, 16:12 -
DVDFab 3.1.4.5 Beta
By devilcoelhodog in forum Latest Video NewsReplies: 0Last Post: 15th Jul 2007, 02:42 -
Beta 2.5 download?
By hordak in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 3rd Jun 2007, 05:59 -
Beta 2.5 first impressions
By mesaboogieman in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th May 2007, 19:25
