I have been having a problem when converting. In the dark scenes of the episode, those objects in low light turn a reddish hue. This is really noticable on people. I was wondering if anyone had any ideas on how I might fix this problem.
I am using an osprey 200 to capture, using Virtual dub with the mjpeg codec (18 quality). Then I use TMPG Encoder with the NTSC SVCD template to encode. The odd thing is when I play the video back on my monitor, before encoding, the shadows aren't so dark and the color doesn't look distorted.
This leads me to think it may be the encoder.
Any help would be appriciated.
Results 1 to 9 of 9
rogue003,
I think this has to do w/ the color
space issue. the MJPEG codec, be
it hardware or software utilizes
a different color space. Why? I
dont know!! But, in my experience,
there's no alternative but to
live with it. some people get so
use to it, they forget there was
even a problem with the color.
You could play around with the col
or settings in tmpg to see it you
can correct the color space issue.
I remember reading something up
on the MJPEG color space issue,
but I can't remember where, and I
believe they had a somewhat vauge
answer to solve it.
If you really want to see these
BAD color space issues, try and
capture "Star Trek Enterprise"
YOU WILL see how bad the color
space issue is for sure.
-vhelp -
Typically, capture codecs operate in the YUV2 colorspace, whereas TMPGEnc operates in the RGB colorspace. There are several possible, albeit imperfect solutions:
1. Run your capture codec in RGB mode, this will probably require a lot of hard drive space for the capture
2. Try doing the colorspace conversion with a tool that might use more intelligent algorithms for it, such as Avisynth
3. Use the color adjustment filter in TMPGEnc to attempt to reduce or correct the effects of the conversion
4. Use CCE, which can encode video in YUV2 without a colorspace conversion -
kinneera,
I was really gearing for the DC10+
cards captures, since its based on
the MJPEG codec or what-not.
You CANT adjust the color space for
the DC10 card though. It's set in
hardware or something, and the conf
in studio or even if I use AVI_IO
have no effect on it. The only
way to ajust colors for DC10+ capt
ures is to do it in the AVI file
after captutes.
-vhelp -
Is the osprey 200 based on the same chip as the DC10+ ? If not, that suggestion might still be useful to the original poster. In any case, I believe you if you say you can't change the colorspace at capture with your card. Still might be worth a shot to try some of the other solutions, though.
kinneera and orig. poster,
sorry, didn't mean to sound like
I was trying to sway you away from
any advise.
-vhelp -
Thanks for the advice. How would I encode in RGB using the mjpeg codec?
And where might I find the Avisynth tool, I don't see it on the tools page.
And as far as the chip on the osprey. The main chip is labelled:
Conexant. Vdub lets me adjust the Brightness, Contrast, Saturation, & Hue. I don't know where to look to find any other color settings. -
This is where I got my version of AVIsynth:
* Here is a website on AVIsynth:
* Here are some other D/L's stuff for you to digest:
* AVIsynth Beta 5 download
There. I hope I have ben helpful this time around
Kinneera,
As far as how to "match" the color
space to other video files, I'd
sure love to know how to do this.
ie, in one movie the colors are
shifted somehow and shows washed
out colors into a richer looking
set of colors, and I'm not talking
about adj Hue or contrast.
I'm talking about "shifing" the
whole color spectrum. If you need
me to be more clear, I have a clip
for ya to D/L (two that is) and
both are from a DVD, but one is
richer in color, while the other's
color, is washed out, though still
nice. let me know if you want more
details. As, I'm still searching
for this golden recipe on color
space shifting ...or whatever you
call it.
-vhelp -
I think the main effect of mismatched colorspaces occurs in the luminence channel, but I am by no means an expert on this. I'm more just aware that the problem exists. In CCE, for example, there is an option that allows you to choose a color range that looks something like 24-252 and one that is from 0-255. The 0 to 255 is RGB, the other is YUV2. Keep in mind that computer monitors are RGB devices, so even if video looks washed out on your computer screen, it may be fine on a TV.
What happened to the orange cone? Vertical Lines in deep reds and oranges.
By Sullah in forum Video ConversionReplies: 12Last Post: 24th Jul 2011, 17:01 -
Reds look wrong for Rec.709
By Anonymous344 in forum Newbie / General discussionsReplies: 11Last Post: 23rd Apr 2011, 19:14 -
Color Problems with Pinnacle Moviebox Ultimate
By fabitos in forum Newbie / General discussionsReplies: 5Last Post: 8th Aug 2009, 23:37 -
Lg 42 lg 3000 color problems
By rambobambo in forum DVB / IPTVReplies: 3Last Post: 9th Oct 2008, 17:23 -
captured video has bad color problems
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 05:24
