Results 1 to 11 of 11
  1. I am building a new PC. Now that we have more choices of SATA DVD writers, should I get a SATA drive in place of its IDE counterpart, in terms of performance, reliability ?
    USA
    Performance and reliability will likely be the same with a SATA optical drive as a PATA drive. But ease of setup should be better than a PATA drive. No jumpers. And the cables are smaller.
  3. Well said! I've been back and forth with my pc maker in regards to slow speeds from my sata dvd drives.
    Live Life 2 The Fullest, Live The Life U Luv & Luv The Life U Live!
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Save the SATA ports for future hard drive expansion.
  5. Member CrayonEater's Avatar
    May 2006
    Cost and availability of the drive that suits your needs is an issue too. SATA drives are presently severely lacking in that regard. Until the availability of a better choice of SATA drives arrives, you are best sticking with a PATA.
  6. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    I have the SAMSUNG 183L SATA dvd burner which burns quite well. I do notice that the device buffer is steady at 100% when burning a dvd disc. Where as all my other dvd burners the buffer goes up and down.
  7. Member MozartMan's Avatar
    Jul 2005
    HockeyTown
    It depends on the SATA chipset of the motherboard.
    I have Gigabyte GA-965P-S3 motherboard with Intel P965 Express and Intel ICH8 chipset (ICH8 handles 4 out of 6 SATA ports).
    I have two LiteOn SATA drives - one is Blu-ray burner, another one is DVD burner. They both work like a charm.
    I saw on CDFreaks forums that people had problems with SATA burners because of other SATA chipsets.
  8. I have the same intel chipset as you on a Asus emery board with 6 Sata ports as well handling 3 hard drives (2 in raid array) and 2 sata burners, and 1 hd dvd rom, I get slow read & write speeds from my optical drives in my benchmarks.
  9. Member MozartMan's Avatar
    Jul 2005
    HockeyTown
    Well, it probably depends on the burner too.
    My LiteOn SH-16A7S DVD burner:
    1. rips DVD-ROM at ~10x
    2. burns 8x DVD+RW at 8x
    3. burns 16x DVD+R at 16x
    My LiteOn Blu-ray burner burns 2x BD-RE disks at 2x.
  10. There are not too many PATA HD drives sold by the stores. They are mostly 160GB and up, as SATA HD drive, available in the stores.
  11. Member edDV's Avatar
    Mar 2004
    depends on the stores.
    http://www.kiva.org/about
