Hey guys,
This is probably hysteric enducing for some of you, but i'm encoding videos to bung on my PS3, but it's taking for ever...about 3 hrs per vid. Given that i'm not a patient man, i was wondering if i could buy anything to speed along the process.
I saw a little usb plug in thingy (video-2-go or something), but that only does iPod size on it's own software. Is there anything available for a home user, that's not insanely expesive that i can bung into my PC to take over encoding from the CPU and speed things up a bit.
I'm encoding stuff at 720p AVC on PS3 Video 9.
Cheers guys
Lee
Results 1 to 9 of 9
720p avc encoding is slow...best would be to get a faster cpu.
maybe this?
http://www.canopus.com/products/FireCoder/index.php
I don't think it does AVC though. -
That's just the sort of thing i'm looking for...just needs AVC support
If PS3 Video 9 is well multithreaded a quad (or even dual) core CPU would be a lot faster than your XP3200+.
Elgato's Turbo.264 does up to 800x600 , 125 bucks , usb stick , mac only for now..
or you could use a Sony AVCHD camcorder for hd ..
or you could get a Sonic HD-Series AVC hardware Encoder
or an ATEME MPEG-4 AVC/H.264 Encoder PC Suite
Tandburg also has a system as do just a few others ..
expect to pay up to around 40 grand"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Using an Onboard video card with a PCI video card
By Nastydave in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Apr 2012, 02:37 -
i7 2600 pc, which graphics card for encoding ???
By glenpinn in forum Video ConversionReplies: 1Last Post: 19th Jun 2011, 08:45 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 13:02 -
will a separate video card speed up video encoding?
By edong in forum ComputerReplies: 12Last Post: 21st Oct 2009, 17:37 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 02:48
