Poll: Does anyone use my guide??!?!?!? It is under the dvd rip section and called the fastest and easiest
Be advised that this is a public poll: other users can see the choice(s) you selected.
Page 2 of 2
FirstFirst 1 2
Results 31 to 40 of 40
  1. Thank´s for the help i dowloadev Ver 1.6 and It works fine
    good quality
    But i do get a real SHIT subtitel any suggestions ??
  2. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    I will try your guide out this weekend. I can benchmark against one I just did.......If it takes longer to encode but less steps involved, it could balance....
    Sep 2001
    N/A
    y do u want subtitles????
    Baker
    My vcd & cvdGuide
    Aug 2001
    Colorado, USA
    poor poor baker, r u that despirate?
    What the Fuc is the internet?
  5. Sure! I used it when learning the basics of DVDx.
  6. I have downloaded your guide as well as DVDX and have had absolutely no problems making VCDs. I use smart ripper to rip the dvds and simply open the ifo file in DVDX and away it goes. The quality of the VCD when it is is done is just fine in fact its better than cable ( mind you thats not saying much lol...). I am doing this in win XP pro 1.1 ghz 320 mg ddr ram with a sony dvd drive and using nero 5.5.7.2. the only drawback doing it this way is you need ALOT of free disk space anywhere from 3.5 to 7.0 gb other than that its just to easy.
    its like the guy on tv says " just set it & forget it "
    good luck and enjoy
    Mike H
    Sep 2001
    N/A
    You do not need to rip the dvd when using my guide!!! DVDx can read straight from the drive.
    Baker
    My vcd & cvdGuide
  8. baker, i hope you included the information that encoding directly from the DVD will keep it working for a few good hours and will shorten the life span of the DVD drive.
    IT IS NOT HEALTHY TO ENCODE DIRECTLY FROM THE DVD DRIVE! your drive will be heated up, and the Media itself could be damaged as well from the heat of the drive.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
    Sep 2001
    N/A
    dvdx has n option called save your dvd drive, In this it rips 20mbs every time it needs some of the film, thus saving the dvd drive from harm.
    Baker
    My vcd & cvdGuide
  10. The problem with that, is that it keeps the DVD spinning in the drive, so it basicly drives the DVD nuts, and yes, i'm presuming you can propably increase the amount of movie it saves up, but the constant accessing to the DVD is not healthy, when you watch a movie for example, you just watch it from start to finish, maybe pause here and there, maybe even skip a chapter, but at the most, you are watching 90min to lets say 2 hours constantly, and then that's it, and if you take out the DVD movie, you'll notice how hot it gets.
    Just imagine the damage that could happen by a constant accessing of a few hours, my point is, just give a fair warning that it can damage the drive and the movie because of over heating.
    Best Regards,
    Sefy Levy,
