I have AVI file with serious A\V sync problem.
whats the best way to fix it?
Thanks!!!
Sync problem how?
- Off by the same amount all the way?
- Good to start with, then suddenly off?
- Good to start with, but slowly driftng out of sync?
- Combination/variation of above?
/Mats -
mats.hogberg,
thanks for the help man!
i wouldnt bother to much either,
but its a video file i've got from a friend and its really important
to me!
The sync is good at the start and then gradually off...
Thanks again! -
First try would be to match audio and video length.
Load the AVI in GSpot, note the play time.
Load the AVI in GoldWave, note audio play time.
Using GoldWave timewarp function, make audio play time match video play time.
Save as MP3
Load AVI in virtualdubmod, disable original audio in stream list.
Add new stream - your duration changed MP3 audio from GoldWave.
Save as avi, with video set as Direct Stream copy.
Worth a try, at least.
/Mats
Is it possible to fix audio sync without reauthoring?
By likwid8 in forum Authoring (DVD)Replies: 4Last Post: 13th Nov 2011, 00:59 -
x264 problem: Movie bad + fix = Digital ghosting and out of sync picture
By Kim Jespersen in forum DVD RippingReplies: 7Last Post: 6th Nov 2009, 17:35 -
Researched No Fix - Sync Problem
By waynepixel in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2009, 13:30 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 18:00 -
Can anyone send me a link on how to fix an out of sync problem?
By gomer in forum Newbie / General discussionsReplies: 2Last Post: 10th Nov 2007, 23:47
