Results 1 to 15 of 15
  1. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Hi, How can I quickly add chapters to a divx movie? Without having to convert back to another format.
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Do you mean a DivX .AVI or a .DivX?
    If the former - it can't be dome. If the latter, try DivX Media Builder. (Or other tool: https://www.videohelp.com/tools?s=116#116)
    /Mats
  3. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    /Mats
    Thanks Mats, I'm not sure, but the file type shows as AVI, and it opens with MP classic which gives this info
    Video: DivX 5 572x236 23.98fps 645Kbps [Video 0]
    Audio: MPEG Audio Layer 3 48000Hz stereo 96Kbps [Audio 1]
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Nope, that wont do. No chapters.
    The "new" DivX 6 container format allows for chapters, menus and whatnot, but not the AVI container.
    You could (without reencoding) turn it into a .divx, but the playback support for .divx is limited.
    /Mats
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If you author to .divx you can play it back in most standalone players, however only the PC based Divx PLayer, or Divx Ultra Certified will see any of the actual authoring (chapters, menus etc). Normal standalone players that can play standard Divx/Xvid etc will simply ignore the superfluous data.
    Read my blog here.
  6. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Well, I decided that I would have to change the format. Then I found that the aspex ratio was way too wide for DVD Author to accept (560x306) so I used SUPER to convert to VCD format, then convert the result( again with SUPER ) to mpeg 2 with AC3 sound. The end result was very good and chapters were added in DVD Author.
    If anyone can come up with a better method, please feel free to comment.
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Some room for improvement, yes.
    A simple way would be to use convertx2dvd. Downside of this, is I think you get chapter points evenly distributed, and can't control this.
    If you're satisfied with the quality you got, fine, but you've thrown a lot overboard with your somewhat roundabout way of going from AVI to DVD specs MPG.
    The fewer steps the better - and use a real encoder like HCEnc. IMO, SUPER produces rather dicey output qualitywise.
    Use FitCD with your AVI to get the .avs script to feed into HCEnc.
    /Mats
  8. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Thanks Mats for your comment. When I look at the movie on my 68cm TV I can not see any difference in picture quality from the original Divx movie,
    There may be a difference,but I can't see it. I don't know how I can get the same result with less moves. I'm very happy with the result.
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    One improvement you could do, while still using the same applications, is to go from AVI to DVD mpg straight away, instead of avi->vcd->dvd. That will improve matters lots, since the VCD step throws most video quality over board.
    /Mats
  10. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    I tried that but it squashed up the picture. I'm just trying the program you suggested and so far it looks good.
  11. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, that's the problem with SUPER - the resizing. But according to another recent thread,
    https://forum.videohelp.com/viewtopic.php?t=326871
    it's possible to solve. It's just rather convoluted.
    /Mats
  12. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Hi Mats, thank you for suggesting CONVERTXDVD it is much better and faster than my method. That's what I like about Videohelp, there is always someone who is willing to pass on their expertise. Thank you again, and keep up the good work.
  13. Member ejai's Avatar
    Jun 2001
    New York USA
    I'm not sure but doesn't Tmpgenc's Divx Author software allow chapters to be added on either .divx or .avi files? I've never ran into the problem of whether I used a DivX .avi or .divx file. It seems to me if you have to convert the file you would be degrading the quality even more.
    It might be worth looking in to.
    Do unto others....with a vengeance!
  14. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Or. I'm sure it can take DivX AVI as source, but the output is in the DivX contaner. Which has limited player support.
    /Mats
