Hey all,
I've got some HDTV .avi content that I need to convert to an .avi at a resolution my Toshiba SD3990 player will accept, as it won't do HD. Is there a guide/how-to on doing that?
Results 1 to 11 of 11
Ok, I got AVI recomp. What resolution should I convert this 1280 X 720 HD content to to play on my Toshiba player? My TV is 4:3. 1280 X 720 is 16:9 widescreen, right? If I converted it to 720 X 480 would that work and look ok on at 4:3?
Thanks. -
What is the maximum resolution listed in the player's manual?
According to this page: https://www.videohelp.com/dvdplayers.php?DVDnameid=6716&Search=Search
- the maximum resolution may be 720x480, but I'm not sure - a post near the top seems to say that it might not like anything over 700.
I'd also recommend AutoGK, with ESS mode enabled, for the purpose. AVI Recomp works, but I've just found AutoGK easier to work with.
If cameras add ten pounds, why would people want to eat them? -
Use 710x400, which will preserve the 16:9 aspect ratio and still be within 720x480. If you convert to 720x480, which is a different aspect ratio, it will make your source video look strange. In fact, a good converting tool should refuse to let you do this, but I'm not familiar with how AVIrecomp works, so I don't know if it will keep you from doing this or not.Originally Posted by Trailryder
Thanks for the replies. I have tried both suggested programs. They both either cause the computer to lock up or the program fails with an error that says something about xvidcore dll trying to access a memory block outside the permitted range. I'm back to square one.
Download this:
http://www.wikiupload.com/download_page.php?id=128556
Use these settings:
This uses a different build of Xvid, built into Mencoder.exe -
Thanks. I uninstalled and re-installed AutoGK a few times as well as Xvid. It seems to be working now. I agree, AutoGK seems to be the better program. I encoded 720x416. Tried converting the audio to 192kbs mp3. Video came out well and plays on my Toshiba but the audio isn't there. I guess I'm going to have to leave it AC3 at 384kbs.
Did you specify VBR MP3 or CBR MP3 under Advanced Settings? Some players might not like VBR audio. I'd wonder if using a lower bitrate like 128 might make a difference, except one of the posts on that player page I mentioned above says that the poster had the same 'no audio' problem with a 128kpbs audio track as with a 192.
I specified CBR 192kbs. The player is supposed to be able to play mp3s. Not sure about an mp3 audio track for a video tho. The original audio is 384kps AC3 6ch. Don't really need that and could save some file size if I could lower it.
Just found out that the Toshiba will play mp3 at 44.1 kHz only, between 32-320kbs CBR. My mp3 track is 48 kHz.
What's the best way to Convert 704 to 720? Avisynth or otherwise
By VideoFanatic in forum Authoring (DVD)Replies: 6Last Post: 23rd Sep 2011, 03:19 -
Best way by using MPEG STREAMCLIP to convert MPEG2 Muxed at 720 x 404 ?
By DTRON in forum Video ConversionReplies: 1Last Post: 21st May 2010, 17:22 -
How to convert .vob file 702x480 to 720 x 480
By illpeeonu in forum Video ConversionReplies: 2Last Post: 23rd Jan 2009, 10:39 -
1080 vs 720
By WuTangDvD in forum DVB / IPTVReplies: 27Last Post: 5th Oct 2007, 20:20 -
How to Convert 1280*720 DivX to a less dimensions DivX
By firas_hashim in forum Video ConversionReplies: 9Last Post: 27th Jun 2007, 09:33
