    Apr 2007
    Canada
    I have WinXP SP1 with Microsoft .NET Framework 2.0 installed.
    This is a new PC on which I want to install my old installation of SVCE2DVDv2.msi
    which I assume is actually version 2.1.2474 since I got it after 10.10.2006.
    But, it complaines that it requires .NET Framework 1.1.4322.
    Can SVCE2DVD work with .NET Framework 2.0?
    What do I need to do to install it again and be able to use it?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    I don't know if it can use Net 2.0, but I doubt it, if it's asking for 1.1. I have both NET 2.0 and NET 1.1 on several computers at the same time and they work together fine. I have programs that use each. I would just install them both.
    NET 1.1: http://www.microsoft.com/downloads/details.aspx?FamilyID=262d25e3-f589-4842-8157-034d1...displaylang=en
    And I would also upgrade your XP install to SP2. JMO.
    And welcome to our forums.
    Apr 2007
    Canada
    Thanks for answering my post. I will try to do as suggested and hope everything will be fine. By the way, I made a mistake in my post, it is WinXP SP2 not SP1. Anyway, thanks again for advice.
