I've read through numerous posts/threads but have not seen anything pertaing to my problem...
So here is my dilema. I have both a MacBoockPro and Desktop PC running windows XP SP2.
I have been using Mediafork/Handbrake on my MBP to convert DVD's to MPEG4. I have been doing so with great sucess. I have then transfreed my files to my PC. They transfer fine. Here is where the problem begins, When I import the mpeg4 file into Itunes, it works fine. However when I try to play the file, all I get is audio. I DO get Visual playback, however it plays back a mix of Hot PINK and Hot Green images. Nothing more nothing less. I have no clue what the problem is.
The file works fine using Windows Media Player, but I really like the cover flow option on Itunes.
Is their a quick fix, plugin etc.. that I am missing?? I attached an image of what the file looks like when being played in Itunes.
Any help will be greatly apreciated!
.::E::.
Originally Posted by elanio
Hm, here's an experiment I'd like you to try: convert a file in Windows using Quicktime to MP4, and try it in iTunes. Seriously, it could be a codec problem on either pc.MKV: Merely Krappy Video.
Subbers, a request from an avid viewer: Either don't use mkv, or supply avi or mp4 as an alternative.
For those frustrated with converting MKV: http://www.immortalmusic.net/mkv/ -
I tried using quick time to convert the file which is either a video clip or Movie File (mpeg).
When I open the file inside quicktime, I get the same results as in Itunes, Pink screen. I am unable to covert it, since the orignal file won't open properly.
I was also thinking a possible codec, but I do have Divix installed.. what other codec could it be? Both the original file and MP4 files play fine inside of Windows Media but not Itunes or quicktime...
I'm dreaming of: A media player that looks like iTunes and supports MPEG-2
By HitTheRoad in forum MacReplies: 1Last Post: 9th Aug 2011, 10:00 -
Flash to Mpeg for Youtube and Itunes
By hellfire45 in forum Video ConversionReplies: 1Last Post: 26th Jul 2011, 04:10 -
a few m4v files have no audio when playing in iTunes...work fine in qt/vlc
By bobogs in forum DVD RippingReplies: 0Last Post: 18th May 2009, 21:21 -
MPEG playing problems
By Dave Knowles in forum Software PlayingReplies: 5Last Post: 14th Oct 2007, 08:31 -
iTunes can't play MPEG-4?
By Sagitta in forum Newbie / General discussionsReplies: 7Last Post: 21st Jun 2007, 22:05
