I am working with dvdremake, and doing test dvds to make sure everything is working before I burn. the only way I can actually get the files to play correctly is if I burn to rw then put it in the dvd player. if I play the folde in windvd, I cant check the menu or press any of the buttons? Is there anyway to make the files play as it would if it was an actual dvd I am playing?
What We Do In Life, Echoes In Eternity....
Thanks so much Baldrick. I always choose source new playlist when viewing dvd projects. Never noticed dvd from folder.
Do you know if its possible to set play dvd from folder as the default?What We Do In Life, Echoes In Eternity....
Is it possible to find the actual stream URL for Air1 to play in WMP/VLC?
By AshleyQuick in forum Video Streaming DownloadingReplies: 4Last Post: 4th Sep 2011, 23:36 -
Play a DVD folder from a hard drive on your TV (without using a computer)?
By coxanhvn in forum Newbie / General discussionsReplies: 15Last Post: 10th May 2010, 16:11 -
Is there a player that will PLAY dvd folder from a flash drive?
By silver007 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th Oct 2009, 16:03 -
Creating DVD-s from VTS folder files
By 1234567 in forum Authoring (DVD)Replies: 6Last Post: 16th Feb 2009, 13:40 -
Do you still play your actual audio cd's?
By yoda313 in forum PollsReplies: 49Last Post: 10th Jun 2008, 11:16
