Hi !
My encoded video suddenly goes black at the end of the movie. I discovered that it was due to the frame rate conversion when converting a 23.976 fps input to a 25 fps in my case. The length of the black picture movie part is equal to the difference in frame number. Let's say you have a 1 hour movie wich represents around 86300 frames played at 23.976fps and 9000 frames at 25fps. The difference is about 3700 frames wich is about 2.5 minutes of black picture I have at the end of the converted movie. Total movie length though is correct, just missing the last 2.5 minutes which turns black. I assume it's a bug in CCE SP2 1.00.00.15 ? Any idea? Any Patch available ?
Thanks,
Seb
It should work.
The simple solution is not to do it.
Encode as 23.976.
Then use dgpulldown to flag it up to 25"I'll give you five dollars if you let me throw a rock at you" -
Thanks for the reply.
I have a doubt... Using dgpulldown to flag it up to 25 will just result in the movie playing faster ? Thus having a shorter movie and loosing audio sync ? I might be wrong, not sure ... I'll give it a try anyway. -
As most PAL equipment have no trouble playing NTSC material, there's no reason to do any frame rate / TV system conversion at all. If it's NTSC to start with, keep it NTSC all the way.
/Mats
black in picture turns green
By heticu in forum Newbie / General discussionsReplies: 2Last Post: 21st Jan 2009, 14:51 -
FLV Frame-rate issue
By djsquared in forum ffmpegX general discussionReplies: 2Last Post: 9th Jun 2008, 17:15 -
Weird frame rate issue. Anybody ran into this before?
By dimtim in forum Video ConversionReplies: 4Last Post: 19th May 2008, 08:21 -
CCE keeps on trying to change my frame rate?
By friedtofublocks in forum Video ConversionReplies: 17Last Post: 14th Dec 2007, 06:21 -
changing frame rate, making a better dvd picture
By motleycool in forum Newbie / General discussionsReplies: 3Last Post: 25th Aug 2007, 03:30
