  1. Member Nox Li's Avatar
    Apr 2007
    Serbia (PAL)
    I have a Sony DCR-HC47E and when I put A memory card in it I can take some photos.Now,how can I transfer those photos into a computer?I already have Sony Vegas and some software that was included in the camera package.
    Life is just a moment that rushes only once.
    Apr 2004
    Miskatonic U
    Simplest methods are either via USB cable, if you got one with the camera, or with an adapter that you put the card into, which in turn plugs into a USB port. The PC will see the card as a removable hard drive, and you can just drag and drop you photos in Windows Explorer
    Read my blog here.
  3. Member Nox Li's Avatar
    Apr 2007
    Serbia (PAL)
    Thanks!!!
