    Dec 2006
    Singapore
    Hi, How do i know what type of files is compatible to play in a standalone divx player? I know avi and mpeg can but they must meet a certain specs rite?
    Apr 2004
    Miskatonic U
    Yep, and they all differ. Your manual will tell you some of the specs, but probably not all. If you want to be sure, buy some DVD-RWs so you can test before committing them to disc for good. If they fail, use AVIRecomp to re-encode to lowest common denominator compatibility.
    Read my blog here.
