Hi!, I own a Canon digicam and have been taking a lot of videos lately, I found out that the only video editor software that seems to work with the files my Canon Digicam produces (.avi files encoded with M-jpg codec) is Windows Movie maker, the problem is that it will only compress to .wmv files which are not appropiate for DVD.
I tested most of the popular video editors, Adobe Premiere 7.0,wonīt open the files, Sony Vegas will only recognize audio but not video, Nero Vision recognizes the files but has a problem when saving, Videowave from Roxio doesnīt recongnize them as well. I know thereīs a workaround recompressing the files to DV but it takes too long and too much HD space, I would stick with WMM but the .wmv videos are not DVD compatible. I wonder if thereīs a good or at least decent movie editor (or movie editor plugin) able to work directly with Canon m-jpg .avi files, edit them and then save in mpge2, Anyone knows?? Thanks, any help very much appreciated
You already answered your own question:
That's the price you pay for quality.Get a faster computer and bigger HD, and everything will work out fine.Originally Posted by flash110
BTW, there are editor apps that'll work with MJPEG, but if you're already having trouble with DV, anything else isn't going to help you. Most MJPEG files are roughly the same filesize and the same computational complexity as DV files (because they're very similarly based on the same DCT technology).
Note: you could just have a codec problem (need to get an appropriate VFW-compliant MJPEG codec like Mainconcept's). Then most if not all of those apps you mentioned would support it natively. But you'll still have the size/speed constraints...
Scott -
First you can output WMM to DV-AVI (Other settings). DV-AVI will be accepted by most DVD Encoders.
Second current version entry home editing software advertise support for digital camera video. Either full Vegas or ULead Video Studio 9 probably loaded the MJPEG (MJPG_MainConcept Video V3.2.4) codec that decodes these files on my system into Vegas, Premiere or Video Studio. I can't say which program loaded the decoder.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Hi, thanks for your replies guys,
Cornucopia:
these mjpg files are about half the size DV files at about 2mb/s, i donīt think this is a codec problem since i can play the files perfectly in WMP and any other player, If you know an application that support these files it would be helpful if you mention the names, I really canīt believe that WMM is the only software supporting these files pretty common in digicam videos
edDV:
I know i can save the files in NTSC DV .avi in WMM but as I said this is too much time/space consumming. I donīt know about ULead Video Studio but I donwloaded the latest version of Sony Vegas and it wonīt recognize the video of these files -
Loading a Canon MJPEG file into NeroVision gets "Unexpected File Format".
The programs that load and play the Canon file are:
WMM
VirtualDubMod (using one of those codecs)
Vegas 6d
Cyberlink PowerDVD 6 Player
VLC Player
Windows Media Player
Nero Show Time
I still don't know which programs loaded the MJPEG codecs. -
When I tested Nero Vision it recognized the files fine but when i saved to mpeg2 the resultéd file had corrupted sound, anyway thanks a lot for your help, I just installed the mainconcept mjpg codec and voila... Sony Vegas recognized the video!Originally Posted by edDV
DubIt Audio Editor - Adding sounds to Video Files
By devilcoelhodog in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2011, 16:54 -
embedding jpg into avi, xvid files
By pheonix rising in forum EditingReplies: 0Last Post: 14th May 2011, 13:54 -
A simple video editor - that works with MKV files (important!)
By jin37uk in forum EditingReplies: 2Last Post: 20th Dec 2010, 21:10 -
Can't find a simple video editor.
By A Traveller in forum EditingReplies: 17Last Post: 28th Mar 2009, 19:05 -
Extracting jpg frames from Video files
By wrazoru in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2008, 05:08
