i'VE TRIED EVERYTHING IN HERE AND I CANT GET A MKV FILE TO CONVERT TO AVI
I'm trying to convert to avi but i can't .
the mkv merge program has an exe named mkv extract but when i use that, it does nothing - a black screen comes up then it closes.
I'm about to throw my whole pc out the bloody window,.
MKV - who invented this crap format?????
Results 1 to 11 of 11
MKv needs a proggy to use EASILY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!
All MKV does is convert back into the same format .
I can see the vid ,audio and subs files but when I demux,it converts to MKV not the other formats.
Going crazy here.
Need my anti depressants.
No more mkv files everyone!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!
Worst format eva. -
Originally Posted by Jellybeantiger
https://forum.videohelp.com/viewtopic.php?t=325530&highlight=
BTW, mkv is a great stuff...just sometimes is a pain in the ass to convert to avi. -
MKVExtractGUI requires mkvtoolnix to be installed to the same directory to work. Do you have both installed to the same directory?
If cameras add ten pounds, why would people want to eat them? -
It only extracts to the same format-mkv.
I extracted the files but virtual dub mod doesn't read them-errors all over the place so I can't use that to convert to avi.
I can play the file on my pc with vlc media player but i need it to be avi so I can use it with sms media player for the ps2. -
download the mkvextratGUI
it's a zip/rar file unzip and place the files in the mkvmerge folder
run mkv extract
press the rest button drag & drop your file into contents window
if it does not show you the video & audio tracks
do reset and try again
took four try for me to get it going
then check ONLY one box the video track and then click the extract button
after that choose the audio tract and extract it
then use avidemux2 to mux them together as a playable Xvid file
if your planning on a DVD , skip the mux step
you will need to run the avi video thru your encoder to get an m2v file for gfd
or use the muxed xvid with convertX
OR you try super but it will make the file bigger and take longer -
Originally Posted by theewizard
If only everyone learned mp4 and AVI are more compatible than mkv...
MKV: Merely Krappy Video.
Subbers, a request from an avid viewer: Either don't use mkv, or supply avi or mp4 as an alternative.
For those frustrated with converting MKV: http://www.immortalmusic.net/mkv/ -
you can use super to extract the audio directly from the mkv to ac3, just be sure the sampling rate is set for 48000 and the bit rate is 192,224 or 384
that way the stream won't have to reprocessed
super also has a volume increase option that works very well, and does not adversely affect the timing ( doesn't mess it up )
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Converting MKV to AVI (720p)
By shorto in forum Video ConversionReplies: 9Last Post: 24th Mar 2011, 05:41 -
Converting .mkv to .avi using AVIMuxGUI
By raphytaffy in forum Video ConversionReplies: 3Last Post: 16th Jun 2010, 21:46 -
By davidw89 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2008, 10:38 -
In need of help with converting .mkv to .avi format
By nabeelnk1 in forum Newbie / General discussionsReplies: 2Last Post: 31st Dec 2007, 15:47
