I am trying to rip a DVD and I keep getting a read error about 70% through. I've had this happen every so often with dvd's.
I clean the dvd's and the play perfectly fine.
I tried copying them using DVD Shrink, DVD Decrypter, Nero DVD Copy and DVD Fab Decrypter.
Could it possibly be using the wrong protection key?
Any suggestions?
hi.....it sounds as if its the disk......when u said it plays perfect did u mean in standalone dvd player or computer.....as many of my DVD's play perfectly on DVD player but wont copy on computer.....try using SmartRipper as thats the soft i use, i dont know, that might help
SmartRipper can't do it either.
It plays fine in a stand alone dvd player and on the computer. -
Read original post
DVD Shrink
DVD Decrypter
Nero
DVD FabDecrypter
SmartRipper
All can't do it. And Ripit4me uses Decrypter/shrink right? -
Ripit4me does! It doesn't work the same way, though.
I've seen a disc rip with ripit4me that I couldn't get through with isobuster or any others, but it worked it's way thru.
You may have to set the tray to cycle on read errors in DVDDecrypter first.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
Disk read error....
By rubberman in forum ComputerReplies: 12Last Post: 12th Feb 2008, 14:06 -
Read Error Issue with Burning
By Evhmoon in forum Newbie / General discussionsReplies: 4Last Post: 10th Feb 2008, 09:39 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
