hi im useing fairuse wizard 2.5 to convert a dvd to xvid. The film is 100 minutes long. Would this be recomended to fit on 1 cd? or should I go for 2??? if so what audio compresion quality shall I use 128kbps??? would 192kbps be possible on a 1 cd rip?
Personally I would go 700MB and 128kbps MP3, but that's because I know that that's good enough quality for me. What you need to decide is, is it good enough quality for you ? After all, you'll be watching it, not me - or anyone else here.
One of the best ways to learn is trial and error. Give it a go at different settings and see what takes your fancy. You'll know for next time then.If in doubt, Google it.
xvid to dvd converting help
By victoriabears in forum Video ConversionReplies: 12Last Post: 15th Nov 2010, 21:00 -
Best settings to use when converting AVI to DVD for 624x464 files?
By Cobra281 in forum Newbie / General discussionsReplies: 5Last Post: 26th Sep 2008, 17:45 -
Converting .Xvid to DVD.... Please
By Galosat in forum Authoring (DVD)Replies: 2Last Post: 18th Sep 2007, 16:10 -
avi to dvd converting settings for winavi convertor
By soft in forum DVD RippingReplies: 6Last Post: 24th Jul 2007, 00:45 -
Converting from DVD to XVID
By morphjk in forum DVD RippingReplies: 11Last Post: 23rd Jul 2007, 17:33
