I am brand new to Mac. I am a longtime Windows user and Pinnacle Studio Plus. I always used Nero on Windows.
I burned a simple slideshow in and with iDVD and was disappointed to see jittery transitions. I posted on apple forums and learned that jittery visuals are not unusual in iLife. Bummer. I am brand new to this so I have not yet made a slideshow in iMovie or Final Cut Express.
I am wondering if I really need Toast or if I will be fine with iDVD. I have looked on line. Still not clear to me.
Can someone give basic advice to a newbie on this? Thanks in advance!
iMac
Final Cut Express/Aperture/Photoshop Elements 3 -
To get Better transitions in your slideshows, you
should make the slideshows in iMovie, or FCE then export
the finalized timeline to a Quicktime .mov file, then QT file to iDVD.
Toast is essential for many other things, such as when
you want to take old footage and just get it to a DVD;
handle odd formats ( to the mac) such as DIVX and
flavors of Mpeg that only by having Quicktime Pro
you could manipulate; and repurpose or combine
existing Video content from DVDs.
Heck, it even makes backing up data a snap too I hear...
I've made slideshows with iMovie, FCP, and Toast.
Both iMovie and FCP make for smoother visuals
as you have to basically build a video FIRST, and FCP alllows
for greater control of transitions between slides.
You would just import the slides and build like you
would a video project; be aware though that your
pictures need to be already sized in PS/PSE3
to the target size output: NTSC @720 x480@72dpi,
PAl @720x526@72dpi BEFORE importing into
iMovie or FCP/FCE.
Toast to me does a better job than iDVD in going from
iPhoto to DVD, but its Motion Pictures add-on, which is
where you make the transitions, is limited to a poor
man's Ken Burns ( pan, zoom, pan and zoom).
So my reccomended workflow is :
iMovie or FCP/FCE, import picts at target size/dpi
Export finalized timeline with transitions to QT Movie
Import QT movie to iDVD, or DVDSP, or to Toast, burn DVD."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
This is one of the most helpful posts I have seen in along time. I have not heard someone recommend the Quicktime .mov step. Thank you, thank you! I am saving this one for sure! Much appreciated.
iMac
HD versus DV
By uno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 10th Mar 2010, 14:24 -
Toast vs. iMovie/iDVD which is better for Mac?
By HowardNeedsHelp in forum MacReplies: 13Last Post: 2nd Sep 2009, 11:42 -
Menu button selection order in iDVD vs. Toast 10 DVDs for MAC
By HowardNeedsHelp in forum MacReplies: 0Last Post: 29th Aug 2009, 12:06 -
iDVD / Toast Compression No Longer Working?
By toxicquack in forum MacReplies: 3Last Post: 26th Jul 2009, 12:57 -
Adding audio to dvd menus - Toast, iDVD, Other?
By Scav2003 in forum MacReplies: 6Last Post: 6th Apr 2008, 02:05
