Results 1 to 13 of 13
  1. I have some DivX files that I downloaded and that I am going to burn to an RWdisc in data format.
    With it came subtitle files. Do I have to use some special authoring program before burning to disc in order to get the subs to work,or do I just unzip it and put it on the disc with the divx file associated with it?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    depends how you are going to play them and if a machine -- what machine
  3. Sorry,yeah it's a Philips 5960/37 which plays divx discs.
    thanks
    Apr 2004
    Miskatonic U
    If it isn't Divx Ultra certified then authoring isn't required. Just make sure your subs have the same name as the associated movie :
    movie_1.avi
    movie_1.srt
    and burn as data
    Read my blog here.
  5. Mod Neophyte redwudz's Avatar
    USA
    And I put them both in a common folder.
  6. Cool,I'll give that a go !
    Apr 2004
    Miskatonic U
    The Philips seems to be unusually picky about subtitles. I know my LG is happy if they have the same name. I just put all the movies and subs in the root of the disc and they play fine.
    Read my blog here.
  8. Banned
    Aug 2002
    beautiful
    any MPEG-4 capable dvd player (doesn't have to be "divx certified") is capable of playing subtitles with the movie, but it have to be text format (SRT is a common standard playable by all of them).
    Some players will play subtitles automatically if the subtitle file name is the same as film file name. However those that don't, and the subtitle have to be loaded/selected manually, those have advantage, because you can have few different (languages or versions) subtitles for same movie
    SRT and SMI are playable by all standalones (MPEG-4 capable).
    However languages other than English are subject to player's font bank in its firmware (i.e. player without cyrillic letters will play subtitle, but the letters displayed won't be readable).
    @gunslinger
    Just reformat your subtitles from any of .txt formats (usually MicroDVD) to .srt (SubRip) and your player won't have any problem.
    For English always select ANSI code.
    For other languages make sure to select their apropiate ISO standard (instead of Windows).
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    <snip>
    With all due respect, I think that's exaggerating. I can well imagine an AVI capable player without support for or both or one of .srt and/or .smi Most support .srt - SMI I have no idea, as I've never used it.
    /Mats
  10. Cool, it actually worked !! Just renamed the sub files(there were 3 of them .idx .sub and .srt ) to the same name as the avi file and dropped all 3 of them in with it.
    Not sure if all 3 had to go in,but I put em all in anyway,and hey presto.
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You may have overlapped languages. .srt is a simple text file, so it has minimal formatting and supports only one language at a time.
    .sub/.idx supports multiple languages in a file.
    Read my blog here.
  12. yeah I noticed that when I went to turn on the subs,it said "01/09 English,so I guess there were multiple languages on there ! Got it working though,so I'm happy now !!
  13. Banned
    Aug 2002
    beautiful
    <snip>
    /Mats
    yeah, I can imagine it too, but that doesn't change the fact that so far ALL of them do support .SRT and .SMI text subtitles.
    If you find one that doesn't please LMK too
