I have a simple TDA-authored dvd (just a main page with "play" button). I want to add a chapter to the movie, but TDA won't import the menu when reauthoring, so I'd have to make a new one. I thought I'd re-do the movie with an extra chapter and insert back into the original dvd.
It seemed to work when I replaced the movie using Pgcedit, played correctly in the computer, but the burned dvd doesn't really show the added chapter. Replacing in Vobblanker is problematic, too. Is there a way to get TDA to import a menu? Or get Pgcedit to make sure the menu structure sees the chapter change?
Results 1 to 1 of 1
PGCEdit question
By gbabione in forum EditingReplies: 14Last Post: 27th Feb 2012, 22:21 -
Edit & Replace DVD menu with PGCEDIT?
By kpic in forum Authoring (DVD)Replies: 1Last Post: 27th May 2010, 17:40 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 12:28 -
Need help with pgcedit's Replace VTST Titles feature TTN's don't match
By ashoun in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 11:34 -
Can you replace a VTS on already authored DVD?
By kpic in forum Authoring (DVD)Replies: 1Last Post: 21st Aug 2007, 08:36
