A new version of our acclaimed video transcoding software has now been announced. Grass Valley ProCoder 3 continues to provide high-speed, high-quality video conversion between multiple formats, incorporating the existing features and workflow options found in ProCoder 2.0, and adding several key new features, including Canopus HQ video encoding profiles, H.264 video encoding/decoding, AVCHD decoding, MPEG-2 Grid Encoding for Multiple/Multi-core CPUs, and Dolby® Digital encoding/decoding support for up to 5.1 channels.
New Features in ProCoder 3
Grid encoding for MPEG-2 (transport stream, program stream)
Based on the same technology featured in EDIUS Speed Encoder for HDV, with more flexibility and expanded controls, the MPEG-2 Grid Encoding support within ProCoder 3 takes full advantage of PCs that feature multiple CPUs and/or multiple cores within the CPUs (including quad core). Parallel-based encoding ultimately yields much faster MPEG-2 encoding times, producing content such as HDV- and DVD-compliant material quicker, saving you time.
Timecode Preservation
If both the source and target video formats support embedded timecode, ProCoder 3 can preserve that information. This makes insert editing possible even after a format conversion.
Inverse Telecine
Content that had previously been converted to interlaced format using 3:2 pulldown can now be restored to progressive film frame rates.
Audio Mapping
When converting files, you can add, swap, and remove individual channels of audio within the target format. This is particularly useful when combined with the new Dolby Digital audio support included in ProCoder 3.
NLE Export Plug-ins
ProCoder 3 includes timeline export plug-ins for Grass Valley EDIUS version 4 and Adobe® Premiere® Pro 2, which provide extensive timeline export capabilities, including DVD-Video image export options.
New Source Formats
* H.264
* AVCHD (M2TS)
* Dolby Digital (AC-3)
New Target Formats and Profiles
* Canopus HQ
* H.264
* iPod (MPEG-4)
* MediaEdge (MPEG-2, MPEG-4)
Results 1 to 30 of 31
I wonder if the price will quadruple with the "Grass Valley" name on it.
Just a word of warning, perhaps. I have ProCoder Express (under the "Canopus" name) which, almost immediately after I bought it and activated it, was pulled from the Canopus/Grass Valley product lineup. I emailed their customer service department and asked them, point blank, if they intended to continue activation support for ProCoder Express in case of a hard drive replacement or computer upgrade experienced by customers. Their terse reply was, "Don't count on it."
They mentioned that ProCoder 3 was coming out soon but made it clear that Edius was their "flagship" product of the future - and suggested I consider buying it. This could possibly mean that ProCoder 3 might be the last version they release - with all future software being under the Edius umbrella (at a more expensive price).
In short, my ProCoder Express is one hard-drive failure or upgrade away from being unworkable ... and ProCoder 2 and/or 3 may be one unsupported dongle away from the same thing.
Hmm ... makes me wonder whether Edius requires a dongle. -
I no longer suggest Procoder. The more I worked with version 2, the more I found it to be faster albeit wholly inferior in quality to version 1. Version 2 had a number of never-fixed errors too, in terms of things it did to video.
I suggest MainConcept at this time.Want my help? Ask here! (not via PM!)
why is it called grass valley?
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
The Grass Valley Group made their fame in High End Video Production equipment. Haven't worked in Broadcast gear in a few years, but I imagine they're still pretty much the best.
http://en.wikipedia.org/wiki/Grass_Valley_%28company%29
PS, Grass Valley is the name of the town they started in.... -
Originally Posted by ron spencer
Now owned by Thomson
http://www.grassvalley.com/products_all/
http://en.wikipedia.org/wiki/Grass_Valley_(company) -
Just curious. Could ProCoder 2 do any conversion (SD type) that ProCoder 1 couldn't do - and did ProCoder 1 require either a dongle or online activation? If neither a dongle nor online activation was required of ProCoder 1, I might start hunting for anyone still selling it -assuming it still had the conversion power. The slowness factor would not be a big deal to me if it performed. -
so did grass valley take over canopus? It was always just canopus procoder....
a year ago almost -- it was family owned for the most part
thanks for the info!!!! Will be interesting to see tis V3 thing. Procoder used to be the cats a** for a while...but seems to have fallen off the map....
Originally Posted by AlecWest
mainconcept h264 will convert from and to a number of formats
I have media Studio Pro 7.3 and I can't get RealMedia to convert at all and MOVs take forever. I usually use AVIDEmux or SUPER to convert them first.
using Uleads version you can convert just about anything to MPEG2........., SWF, MOV, RM, WMV, QT -
Originally Posted by dvd3500
Edit: Actually I ws going from memory and now that I look I don't have an option for importing RM but only for exporting.
That really makes no sense, it's usually the other way around.Unless i got something screwed up in the registry. I've recently lost my ability to select Dolby Digital so that may be the case.
@thecoalman:
There's an .ini tweak that will get that back AND allow you to tweak the MPEG settings.
It's explained her ein French:
http://forumvideo.tavis.info/forum_posts.asp?TID=12493&PN=1
PM me if you need help. -
Grass valley has great ideas but lousy customer support. Just call them about a problem with there hardware...They will started speaking Russian....
Originally Posted by Marvingj
Call Boeing to complain about your dead headset connector and expect a similar response.
* The historical customer ethic of this company would cause employees to avoid planning weddings or childbirth during the Olympics, Presidential Elections, Superbowl, NAB convention or World Cup where all hands were needed to be on deck. Thomson operates by the French ethic. -
It seems to be officially released now http://www.canopus.com/products/ProCoderSW/index.php, but I can't find any price for the upgrade version. Buy.com has the full version listed at $444.97 http://www.buy.com/prod/ProCoder_3/q/loc/105/204518096.html, but no upgrade. Anyone know the upgrade price?
if you are wondering what "Rhozet" means in the above screen shot -
procoder 3 was written / tweaked / by the Rhozet Corporation (who first wrote the sdk procoder was based on - and refined in japan)
Rhozet Corporation is the creator of Carbon Coder, which is a stand-alone application that handles transcoding between all major formats, as well as providing a host of additional functions like standards conversion, logo insertion, timecode burn-in, etc.
It is used now by almost ALL major networks and studios for one thing or another -- along with sonic and/or avid , etc .. hardware/software ....
Supported Formats
Video Codecs
* MPEG-1, MPEG-2, MPEG-4
* H.263, H.264, VC-1, Flash
* DV25, DV50, DVCPro
* DPS, DivX, JPEG 2000
* Image Sequences
* Windows Media, RealVideo
Media Containers
* HDV
* MXF (including D-10/IMX)
* MPEG-2 PS, MPEG-2 TS
* GXF, LXF, QuickTime
* WMV, ASF, AVI, VOB
* 3GPP, 3G2
* WMA, WAV, Broadcast WAV
Audio Codecs
* PCM, MP3, DTS
* AAC, AMC, AMR-NB
* WM Audio, RealAudio
Systems
* Leitch VR, Nexio
* Grass Valley Profile, K2
* Omneon Spectrum
* Quantel sQ
* Avid Editing Systems
* Apple Final Cut Pro
* Adobe Premiere Pro
* Grass Valley Edius
Additional Functions
Basic Operations
* Frame size conversion
* Frame rate conversion
* Color space conversion
* Aspect ratio conversion
* Interlace/de-interlace
* Telecine/inverse telecine
* PAL/NTSC conversion
* SD/HD conversion
* Cropping
* Key-frame extraction
* Multiple target outputs
* Batch processing
Advanced Operations
* Timecode imprint
* Subtitle/CC imprint
* XML controllable titler
* Metadata transport/conversion
* Line 21/CC conversion
* Watermarking
* Logo insertion
* 601/709 color space support
* Video capture board support
* Remote job submission
* Watch folder automation
* Segment extraction/insertion
Video Filtering
* Fade in/out
* Median
* Blur
* Sharpen
* NTSC-safe
* Rotate
* Black/white correction
* Color correction
* Gamma correction
* Temporal noise reduction
Audio Filtering
* Normalize
* Low-pass
* Fade In/Out
* Volume
* Dynamic range compressor
Carbon Coder is $4995 plus $795 a year plus (i think) $495 per render farm cpu
procoder 3 is its little brother ....
procoder express is its baby baby brother i guess ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by BJ_M
Spoke to Grass Valley sales...Upgrade is only available through Grass Valley (so don't waste your time searching through dozens of Canopus dealers like I did
) and as BJ_M said, is $199. Upgrade is good for owners of Procoder 2 and Procoder Express for Edius. The salesperson told me they are selling Procoder 3 direct for $499.
As a side note, Procoder 2 seems to be pretty much sold out and most dealers have not yet added Procoder 3 to their inventory. Guy Graphics http://www.guygraphics.com/GGPROD-75415.html has it for $449 though. -
I'm still using Procoder 1.5. I had major success with it right outta the box and never looked back.
2.0 did not offer anything I needed right then, and 3 does not sound like something I need right away.
Sometimes it is a good idea to sit by the sidelines for a while and watch the cars go by.
I don't care about speed as much as quality, and Procoder got it right the first time. Beautiful picture when you have good source footage.
ReactOS: The Russians Are Coming, The Russians Are Coming (Maybe?)
By CobraPilot in forum ComputerReplies: 12Last Post: 16th Sep 2011, 23:21 -
Jitter coming out of projector
By KayAt in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2011, 10:55 -
The Second Coming of jeex
By jeex the II in forum Off topicReplies: 9Last Post: 22nd Oct 2010, 21:47 -
Google TV coming
By jagabo in forum Latest Video NewsReplies: 3Last Post: 21st May 2010, 15:21 -
When is V3 coming???
By mbmapit in forum SVCD2DVD & VOB2MPGReplies: 23Last Post: 1st Nov 2008, 17:11
