I have some mov files that I downloaded from a newsgroup. When I try to convert them to mpg2 (using either MainConcept v1.04.02.00 or TMPGenc Xpress v3.1.5.81) I end up with audio and a white screen. No video.
Using MainConcept, as soon as I try to load the file I get a message from Quicktime saying: "Quicktime is missing software required to perform this operation. Unfortunately it is not available on the Quicktime server." MainConcept goes ahead and loads the file, and completes the conversion process, but with the result as noted above - audio but no video.
Using TMPGenc Xpress, no warning message appears but the result is the same. Everything seems to be proceeding normally, but with the same result - audio but no video.
Also, the files will play just fine in VLC Media Player, but they will not play in Quicktime. If I try to play them with Quicktime a message appears telling me that I may experience problems playing the file because the required compressor could not be found. If I continue, then I get sound but no picture.
I've converted other MOV files with no problem with MainConcept and TMPGenc. This is something new to me.
Is this a codec problem or what?
upgrade your qt to the latest version
I just checked for updates, and I have the current version, v6.5.2. It's not QuickTime Pro, but it is the latest of the free version. Is it necessary to have Pro?
OK. I clicked on the "Check for Updates" in one of the menus in QuickTime, and I was told that the version I was using was current. I'll do a search and dig around some more. Thanks for the tip.
help -No sound when converting .mov files
By bloke666 in forum ffmpegX general discussionReplies: 0Last Post: 11th Dec 2011, 11:48 -
Converting or Joining MOV files
By theWallflower in forum Video ConversionReplies: 3Last Post: 8th Apr 2010, 07:00 -
Batch Converting MOV Files
By thomasj in forum LinuxReplies: 3Last Post: 25th Dec 2009, 14:50 -
Converting files to Mov For (CyberPix DV-20 CM-ME-DV-20HDRD)
By Zerodude in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2008, 08:48 -
converting .mov files to something I can use
By weazel_k in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 16:46
