1st of all let me tell you that i have a movie which is on DVD9 disk and it is quite small in size ONLY 4.85GB! I want to copy it to normal DVD +/-R with conserving as much as possible from the original. I'm asking because the original quality is quite far from DVD quality and if the I compress it with improper software maybe it will be the same as rip it to divx...
the dvd is not encoded...
so any advice???
Problem conserving 5.1 from MKV conversion
By l'ensemble in forum MacReplies: 1Last Post: 24th Jan 2011, 14:35 -
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 11:37 -
Easy MKV -> DVD application? Want 5.1 and max quality (4,4 GB or DVD9)
By bjorsa in forum Newbie / General discussionsReplies: 19Last Post: 3rd May 2010, 12:08 -
The best possible quality of DVD9 to DVD5
By Charmer in forum DVD RippingReplies: 37Last Post: 28th Apr 2010, 19:00 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 00:30
