Closed Thread
    Apr 2007
    Hi there-I am new to this forum but not so new to using Convert X-I am new to using Bit Torrent and U Torrent and have got some files that I was able to convert to dvd and burn with no problem but now the last three downloads will not convert. It just says it is not able to convert the file. I usually use Limewire but do to the increase in bogus and corrupt files and spyware I switched to Torrent. Is it possible that some of the files are not able to be converted?-I have never had this problem with the VSO software. I updated and I am using the latest version. What could be the reason that a typical video file would not convert-I also burn using 1 Click DVD Copy-I have alot of HD-350gb-and 1 gb of ram-I only use about 25% of the two HDs-I use Maxell DVD-RW- which have been great and save alot of money by reusing-The videos will burn just fine but will not convert' so what could be the problem?
    Apr 2004
    Miskatonic U
    This is what happens when you download suspect files from suspect sources.
    Just out of curiosity, what is the extension on the these files ?
    Read my blog here.
    Apr 2007
    One says-Children.of.Men.2006.PL.DVDRip.RMVb-BitCoders--------size 306 mb-in 6 files-
    You are in breach of the forum rules and are being issued with a formal warning.
    Buy it on DVD. This is not the place to get help with illegal downloads.
    Read the rules agan.
    / Moderator mats.hogberg
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If in doubt, Google it.
    Apr 2007
    I started using U Torrent just this week because I have heard the files were usually good and very little garbage like what has happened to Limewire-Others I have had no problem with on there-I am new to that system so it very simply be operator error-File sharing is starting to get to be more work to root out the evil doers as GW calls em-
    Jul 2004
    Originally Posted by jimmalenko
    The Devil`s always.....in the Details!
    Apr 2004
    Miskatonic U
    Have you read the rules of this forum ? Specifically the bits about piracy, warez and discussion illegal software and movies ?
    Might be worth going back and reading them again.
    Read my blog here.
