I recorded clip from cable STB using iRecord (M2T format) and it plays fine with audio using VLC. Drag same clip into FFMEPGX and get no audio. File converted and has no audio in iMovie or QuickTime. Converted file (ff.avi) also has no audio in VLC.
When I drag clip into FFMEPGX and hit play there is no audio. I have tried experimenting with settings under audio but with no success. Can't find any similar problems posted here.
Any suggestions would be appreciated.
Thanks,
Steve
Results 1 to 15 of 15
One quick thing to try is "invert mapping" (which changes the order in which audio and video are interleaved in the file).
And if that doesn't work, unclick invert mapping, and try again. After it fails, click on the "i" button and post its contents. The status and error messages (if any) may offer a useful clue. -
Thanks for suggestions
Tried "invert mapping" with no success.
I have no audio when I hit play even before encoding.
contents of "i" are below.
Encoding started on Fri Apr 6 11:50:12 EDT 2007
MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
Mac OSX static build for ffmpegX
FIXME:Hardenabling SSE and SSE2 without detection
CPU: Intel (Family: 6, Stepping: 8)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
success: format: 0 data: 0x0 - 0x4e80b90
TS file format detected.
DEMUX OPEN, AUDIO_ID: 0, VIDEO_ID: -1, SUBTITLE_ID: -2,
PROBING UP TO 2000000, PROG: 0
VIDEO MPEG2(pid=361)NO AUDIO! NO SUBS (yet)! PROGRAM N. 0
Opened TS demuxer, audio: ffffffff(pid 0), video: 10000002(pid 361)...POS=0, PROBE=2000000
VIDEO: MPEG2 1920x1080 (aspect 3) 29.970 fps 80000.0 kbps (10000.0 kbyte/s)
[V] filefmt:29 fourcc:0x10000002 size:1920x1080 fps:29.97 ftime:=0.0334
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=1920 h=1080]
The selected video_out device is incompatible with this codec.
Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 1920 x 1080 (preferred colorspace: Mpeg PES)
VDecoder init failed :(
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
Forcing output fourcc to 58564944 [DIVX]
VDec: vo config request - 1920 x 1080 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
videocodec: libavcodec (1920x1080 fourcc=58564944 [DIVX])
1 duplicate frame(s)!
Writing header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
Writing header...
Writing header...
demux_mpg: 24000/1001fps progressive NTSC content detected, switching framerate.
... many more "1 duplicate frame(s)!" removed for this post . . .
demux_mpg: 30000/1001fps NTSC content detected, switching framerate.
Warning! FPS changed 23.976 -> 29.970 (-5.994005) [4]
TS_PARSE: COULDN'T SYNC
Flushing video frames
Writing index...
Writing header...
Video stream: 1433.394 kbit/s (179174 B/s) size: 11323193 bytes 63.197 secs 1531 frames
Encoding completed on Fri Apr 6 11:51:07 EDT 2007 -
From VLC's Info palette, what does it say
about the audio stream? The one that plays
in VLC.....
Your more than likely missing a codec....
Not familiar with iRecord, and what it encodes
audio as or if it has a selection to choose encoders
for audio, like Audio Hijack, Wiretap, iShowU, etc."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
When you play the original in VLC, take a look at the Info data and see what it says about the audio codec type. It should be ac3 (I believe), but maybe something strange happened along the way.
Also, try demuxing the original .m2t file. If it correctly gives you two valid elementary streams, you can transcode these separately, and remux afterwards. That might work around whatever problem you're having.
MpegStreamclip is another possibility. See if you can play the file there. If so, have it export to mpeg. That might convert the file into a form that ffmpegx and others can handle without these troubles.
Of course, the best solution is for Case to find this problem interesting, and have him chime in.
Thanks for your guidance.
audio codec in VLC is listed as a52
I installed mpegstreamclip and not it seems I can no longer record with iRecord.
I've working on this problem without success. Still trying though. -
Try reinstalling iRecord. Does VLC play the file fine again?
If you want to use MpegStreamclip, you'll also need the MPEG2 component (it's not free, but it's not expensive). If you don't have it, QT can't play it, either.
You may want to take a look at this guy's notes on doing something similar:
http://joshnichols.com/2007/02/17/rip-recorded-video-powerbook/ -
Tomlee,
Thanks again. I got iRecord working somehow. Lookslike Josh has been down exactly the same road. I'll follow up with his roadmap tomorrow.
Steve -
Go and install the codec for A52 decoding/playback from here:Originally Posted by smillerdad
QT A52 component
This will enable audio to be played in QT."Everyone has to learn, so that they can one day teach."
Urban Mac User -
Still no audio in ffmpegx
Installed the A52 component as directed, no audio.
Restarted mac, still no audio
Put a52 codec component into ffmpegx app support folder, reatarted ffmpegx and still no audio.
I'd use mpegstreamclip as suggested but Apple website for MPEG2 component states:
"Can the QuickTime MPEG-2 Playback Component play back AC3 audio?
No, MPEG-2 files containing AC3 audio cannot be played back with the QuickTime MPEG-2 Playback Component. "
My iRecord (and AVCVideocap) files have AC3 audio
Any suggestions as to what I am missing here? -
Did you try demuxing the m2t file? At minimum, we can implement a divide and conquer strategy, because there are several ways to transcode an ac3 file into other formats.
Can't demux in ffmpegx. "Unercognized format. You can only demux .mpg, .vob or TiVo files"
More detailed research suggests that although Quicktime can't deal with AC3 audio, mpegstreamclip says it can. It's worth the $20 to try it since I've spent so many hours beating my head against a wall.
Thanks again, I'll post my results. -
Im getting files into iMovie with sound. mpegstreamclip and QuickTime MPEG-2 Playback from apple were the key. Would have rather have done the conversion in ffmpegx but couldn't get ac3 audio to come through. Hopefuly the workflow will get streamlined in the future.
Thanks again to tomlee59 and terryj who passed on good suggestions which finally helped me to "skin the cat" another way.
Anyone else trying to get HD video from a cable box into iMovie should refer to the joshnichols blog listed above for an excellent roadmap.
Regards,
Steve -
Congrats for having hung in there, Steve. Some cats can't be skinned at all; glad you found a way in this case!
smillerdad,Originally Posted by smillerdad
Good stuff. I'm kind of in the same boat, but I can't MPEG streamclip to show the video, let alone play the ac3 audio. The m2t file works fine in VLC; ffmpegx says there is no audio; and streamclip gives me nothing (and I made the mistake of spending $20 for the QT playback). I took those steps of adding the ac3 to ffmpegx and have re-installed streamclip.
Any advice?
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
