hey guys i have a question on my sony dru-710a ok it used to burn both dvd-r /dvd+r
but now it just wants to burn the dvd+r and not the dvd-r can it be the setting or???
if anyone can help me out it would much appreciated thank you
GQ 16X and they both uesd to burn the movies i get ?
Originally Posted by budz -
Use DVDINFO PRO or DVD IDENTIFER to find out the MEDIA ID for GQ 16x dvd media. My bet is the discs you're using is junk. Try using VERBATIM or TAIYO YUDEN dvd media.
Btw your SONY 710A dvd burner is a rebadged BENQ 1640 drive. You could crossflash your drive to the official BENQ firmware and use QSUITE 2.1 to tweak your burns. -
GQ is the generic brand used at Fry's Electronics. You never know batch to batch if they are the same manufaturer. Try a better brand.
I have a Sony DRU-710a (made by Lite-On). Mine works with many but not all DVD-r but only works with +RW not -RW so far. I hear there is a firmware update for -RW.
sony dvd rw dru-190a problem
By videodude1966 in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Apr 2010, 04:53 -
Problem with Sony DVD RW DRU-830A
By VOD0708 in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Jan 2010, 15:43 -
where to get original Sony DRu-820a DVD Firmware
By scustalow in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jun 2007, 12:00 -
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41 -
Sony DRU-820A DVD Drive suddenly burning slow
By progrocktv in forum DVD & Blu-ray WritersReplies: 3Last Post: 24th May 2007, 22:55
