TIA for any assistance, the folks at Nero are not responding to my tech support questions and I'm getting tired of waiting.
My issue: I use Nero to burn DVD's. I have a Sony DRU 830A burner, and am using Nero 7 enhanced. I have used this same combo for a few years, but just replace the burner last week as the previous one needed to be retired. I burn .vob files to dvd -R discs and have had no issues till the new burner was installed. Now, when I burn these files, the completed DVD will not play in the rom drive of my computer and is being identified as RAW format. But the same dvd WILL play in a stand alone dvd player just fine. The disc is finalized, but will not play in my computer. I have lastest firmware installed for the Sony burner.
Can someone help me figure out what setting I need to change to make these otherwise playable dvd's work on my computer?
Results 1 to 1 of 1
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 12:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 20:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 14:40
