this past weekend i converted some of my dvds into vcds. well they work fine on my standalone dvd player but when i tried them on my mothers and my brothers it played them but the image on the tv looked like a scrambled cable channel (rolling frames, static, black and white). I did these vcds in pal format. is there a way i can fix them so i will be able to play them on other dvd players. Any help with this would be greatly appreciated. Thanks in advance.
You mentioned that you did the VCDs in PAL format. What format is your TV, and what is the format of the other TVs and DVD players you played them on. Sounds like the other TV/DVD players were NTSC (American). Some DVD players can handle either PAL or NTSC and others can't. It sounds like that is probably the situation here.
ok thanks, next time i will try it ntcs format being that i do live in america
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 10:55 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 14:16 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
MPEG playing problems
By Dave Knowles in forum Software PlayingReplies: 5Last Post: 14th Oct 2007, 08:31 -
Problems with recorded TV playing
By amir77a in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Jun 2007, 08:57
