    Nov 2002
    East Moline. IL
    Hi friends,
    I have 150 songs from various sources with different sound quality. I want to make them uniform like with same volume(sound) , clarity and amplitude etc.,
    Can anyone sugest how to make them uniform by telling some editors or some websites which explains this or any information to acheive good quality for all the tracks.
    Thanks in advance.
    ~vvkp
    Knowledge is power and you will get more and more if you share with others!
  2. For MP3 I use MP3Gain because it's lossless,for WAV I use Audacity.
    NOTE:if the quality of the source is bad then there's little you can do to improve it.
    Nov 2002
    East Moline. IL
    Thanks for your reply. Is there any tool, suppose if I give a track as speciman so that it should convert all the remain tracks same qulity like the speciman? What I mean is all the tracks should be uniform.
  4. What do you want?
    Same quality=No
    Same volume=Yes
    Same bitrate=Yes
    You can batch normalize with either or batch encode with Audacity,another good batch encoder is CDex.
  5. Member olyteddy's Avatar
    Dec 2005
    You realize that in making them 'uniform' you aren't gonna be able to do too much to make the bad ones better? That is, you'll have to make the great ones worse to match the bad ones. Except for volume changing.
  6. Member Soopafresh's Avatar
    Jan 2004
    21 day Trial. AAMS auto mastering system. It isn't bad, but it is slowwwwwww.....
    http://www.curioza.com/
    I would take MOVIEGEEK's advice and just automate something with Audacity. There are also nice filters in Foobar .
  7. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    I believe dBPowerAmp should be able to do this from Explorer, too.
