Hi, I'm trying to compress .avi video file (that was captured with fraps) using Divx 6.5.1 codec with VirtualDubMod 1.5.10.2 and AutoGK 2.40 , but i always get this error: The source image format is not acceptable. (error code -2). Also i get this .txt file, maybe it's useful:What can i do?Code:[2007.04.04 22:24:54] AutoGK 2.40 [2007.04.04 22:24:54] OS: WinXP (5.1.2600).2 [2007.04.04 22:24:54] Job started. [2007.04.04 22:24:54] Input file: C:\Documents and Settings\Adomas\Desktop\PES6 2007-04-04 21-40-47-96.avi [2007.04.04 22:24:54] Input codec: FPS1 [2007.04.04 22:24:54] Source duration: 30s 733ms [2007.04.04 22:24:54] Output file: C:\Documents and Settings\Adomas\Desktop\PES6 2007-04-04 21-40-47-96_agk.avi [2007.04.04 22:24:54] Output codec: DivX [2007.04.04 22:24:54] Audio: none [2007.04.04 22:24:54] Subtitles: none [2007.04.04 22:24:54] Format: AVI [2007.04.04 22:24:54] Target size: 1400Mb [2007.04.04 22:24:54] Started encoding. [2007.04.04 22:24:54] Source resolution: 800x600 [2007.04.04 22:24:54] Source fps: 30 [2007.04.04 22:24:54] Analyzing source. [2007.04.04 22:25:54] Source has percentage of interlacing in motion areas: 0,00 [2007.04.04 22:25:54] Source has percentage of telecined patterns: 0,00 [2007.04.04 22:25:54] Source has percentage of progressive patterns: 100,00 [2007.04.04 22:25:54] Source has percentage of interlaced patterns: 0,00 [2007.04.04 22:25:54] Source is considered to be progressive. [2007.04.04 22:25:54] Output will contain 922 frames [2007.04.04 22:25:54] Overhead: 25,600 bytes (0.02 Mb) [2007.04.04 22:25:54] Video size: 1,467,980,800 bytes (1399.98 Mb) [2007.04.04 22:25:54] Target bitrate is: 382121kbps [2007.04.04 22:25:54] Running compressibility test. [2007.04.04 22:25:54] Writing the following script to C:\Documents and Settings\Adomas\Desktop\agk_tmp\PES6 2007-04-04 21-40-47-96_agk_comptest.avs =========================================================== LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrainSSE3.dll") movie = DirectShowSource("C:\Documents and Settings\Adomas\Desktop\PES6 2007-04-04 21-40-47-96.avi",30).KillAudio() movie = isRGB(movie) ? ConvertToYV12(movie) : movie movie = isYUY2(movie) ? ConvertToYV12(movie) : movie cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=0,samplestartframe=0,leftadd=0,rightadd=0,topadd=0,bottomadd=0) fixed_aspect = 1 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = (input_par > 1.4) || (input_par < 1.25) ? input_par : (4.0/3.0) out_width = 704 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=0,samplestartframe=0,leftadd=0,rightadd=0,topadd=0,bottomadd=0) LanczosResize(out_width,out_height) SelectRangeEvery(14,14) =========================================================== [2007.04.04 22:26:03] Duration was: 9 seconds [2007.04.04 22:26:03] Speed was: 100,18 fps. ************************************* EXCEPTION: Open avi failed. ************************************* [2007.04.04 22:26:03] Job finished. Total time: 1 minute, 9 seconds
Compressing an uncompressed AVI for Adobe Elements 10
By Daniel_BMS in forum EditingReplies: 5Last Post: 9th Mar 2012, 19:57 -
compressing avi files
By romanstopme in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2009, 20:36 -
Compressing Avi
By Tony11 in forum Newbie / General discussionsReplies: 2Last Post: 4th Feb 2008, 01:30 -
Compressing AVI Files to Burn to DVD?
By ryevick in forum Authoring (DVD)Replies: 17Last Post: 27th Nov 2007, 21:59 -
Having problems compressing AVI file
By nucklhead24 in forum Newbie / General discussionsReplies: 6Last Post: 17th May 2007, 22:42
