    Mar 2007
    Philippines
    How to embed .sub to xvid using virtualdub?
    Pls help I tried opening the subs using DivXLand Media Subtitler
    It says failed to determine subtitle format. Not yet supported
    Any easy way to do it? Like convert sub to ssa?
    I tried renaming the sub files to ssa but it ended up in a disaster subs were way out of sync with the movie
    I downloaded subs of the movie in txt format and still out of sync
    Coz When I open the add->filter in virtualdub it only supports .ssa
    USA
    You would likely get more answers in our Subtitle forum. Moving you.
    And check the stickies at the top of that forum and you find most of your answers.
