I was wondering how you can seperate the audio from the video in Vegas 7 so they are not locked together. For example if you want to manually sync audio and not thave the video dragging with it
please hlp, Im on a deadline but just started using vegas
I only have Vegas 6 but it's probably the same.
1. Select either the video or audio track.
2. On the toolbar, click on the button for "Ignore Event Grouping" or press Ctrl+Shift+U.
3. Also make sure that "Quantize to frames" is deselected or you'll have trouble getting the sync exactly right (because otherwise Vegas forces the audio to start at the beginning of a frame).
As soon as you have the sync set, DE-select Ignore Event Grouping and RE-select Quantize to frames, so everything else you do for the rest of the project doesn't interfere with the sync you just set.
Hope your project goes well.
Easy audio and video stream splitting application suggestions please
By roberta in forum DVD RippingReplies: 2Last Post: 21st Feb 2010, 16:12 -
Splitting and joining different content and video formats with new audio
By shrinkage in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2009, 11:17 -
HELP PLEASE URGENT "video audio codecHelper has stopped working"
By kidkool in forum Video ConversionReplies: 3Last Post: 1st Jun 2009, 09:54 -
Final Cut Express- splitting audio from video
By ker-plop in forum MacReplies: 10Last Post: 4th Jul 2008, 15:40 -
Video/audio file splitting weirdness
By DoctorDidj in forum ffmpegX general discussionReplies: 2Last Post: 13th Jun 2008, 07:28
