I need to hook my camcorder up straight into a digital projector.
I've a Canon GL2 with a firewire output and the projector has a RGB input.
Is there such thing as a Firewire to RGB convertor?
Thanks,
Does the projector have composite or S-video inputs? (i.e., a yellow RCA connection for composite)?
If so, you might as well use the GL2's analog outputs.
A FireWire (DV) to RGB dedicated converter will be rather expensive.
Even if the projector only has RGB inputs, it would be cheaper to get a composite-to-RGB or S-video-to-RGB converter.John Miller -
I connect mine directly S-video to S-video. Looks great!
I also occasionally run my camcorder's firewire through my Toshiba RD-XS35 DVD recorder to the projector as a kind of ad hoc firewire to RGB converter, but since the camcorder's DV-AVI format is only 720x480, the difference is hardly noticeable.
HD video camera hookup to digital projector
By MTguy in forum Newbie / General discussionsReplies: 4Last Post: 1st Feb 2011, 20:08 -
HELP! Camcorder to projector live feed
By gandcsundvik in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 20th Jul 2010, 23:03 -
Playing live video from camcorder through computer to digital projector
By StevieBlunder in forum MacReplies: 6Last Post: 3rd Jun 2008, 12:36 -
Best/Least Expensive Camcorder for Streaming (Straight to HD)
By enter8 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 19th Dec 2007, 19:23 -
Capturing from my DV camcorder: artefacts with straight lines (fuzzy)
By hydrocynus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 14th May 2007, 20:56
