all was great before I installed Tmpeg DVD author w/divx support
I record live TV with WinVDR and divx 6.5 to avi format, dx50 is the 4cc
records gr8
plays with divx or ffdshow in zoom player
but
when I try to inport it into virtualdub 1.6 it ID's it as xvid - virtualdub crashes
change 4cc to "xvid" - virtualdub crashes
change 4cc to "divx" - all is well and bye bye adds, chop chop
any ideas on how I can tell virtualdub that dx50 is divx and not xvid
thx
Start -> All Programs -> Xvid -> Configure Decoder -> FourCC Support -> uncheck DX50.
want to figure out why so I can use Tmpeg DVD authorOriginally Posted by jimmalenko
wierd, no Xvid in my start menu, even tho I have it installedOriginally Posted by jagabo
jagabo any chance you could post the target line from xvid config shortcut
would rather not get into a install/uninstall cycle untill i've tried enerything else
thx for the ideas guys ! -
Xvid Config shortcut:
C:\WINDOWS\system32\rundll32.exe xvid.ax,Configure
Paste into Start -> Run
How to convert DV to DivX or XviD using Virtualdub
By Baldrick in forum User guidesReplies: 52Last Post: 1st Dec 2011, 18:04 -
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Divx/Xvid problem in Virtualdub (not mod)
By leeqk in forum Newbie / General discussionsReplies: 14Last Post: 11th Apr 2010, 02:18 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Problem with Divx/Xvid with Winamp and Virtualdub
By mekuka_pinasem in forum Software PlayingReplies: 5Last Post: 1st Aug 2007, 12:41
