I have a divx avi movie I would like to show my kids. The problem is that there are a couple of sex scenes I don't want them to see that I want to cut out. Otherwise the movie is fine.
Can someone advise how to cut out part of an AVI movie. I have Adobe Premiere 6.5 that I hardly use. I don't know if that will do it. I don't know what to render the film in once I'm through. Couldn't I just cut out the film clips without the long hours of rendering?
you could just tell them not to look or explain what sex is and why people get hung up on sex in a movie but showing massive violence is ok
you can just use virtualdub and cut the sections out without re-encoding...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thank you for the information and quick reply. And I completely agree with you. But there have been problems in school where other kids have reported what they have seen at home and school officials quickly contacted social services. I don't want to be a victim of such a lynching.
Edit a movie (avi), cut some scene but KEEP subtitle in synq! HOW TO??
By GiBsom in forum EditingReplies: 5Last Post: 18th Dec 2013, 18:58 -
HOW TO EDIT MPEG4 FILES IN (DIVX).AVI, .mkv and .mp4 Containers
By jhb50 in forum User guidesReplies: 0Last Post: 18th Jul 2009, 22:32 -
Magix movie edit 12 - Divx export fails
By pete76 in forum EditingReplies: 1Last Post: 4th Jun 2009, 04:32 -
DivX Player 6.82 cannot play AVI movie
By chuckycheese in forum Software PlayingReplies: 10Last Post: 24th Jul 2008, 22:10 -
DVD to AVI (no divx!) to edit in Pinnacle software?
By erol in forum DVD RippingReplies: 1Last Post: 7th Sep 2007, 03:33
