Well I am converting my OGM files to .VOB using ConvertXtoDVD and it has been working great for any file.
What I do is I take the converted files into a new program which is Ulead DVD Movie Factory 5 and it burns great. Now my problem is when I convert OGM it gives me a .VOB file with 2 audio tracks.
One track is Japanese and the other is English. Before I converted it Japanese was audio track one and English was audio track 2. When conversion was done English was first and Japanese was second.
My problem is that when I import the video to Ulead DVD Movie Factory 5 it takes the second audio track making it Japanese.
I want to know if anybody can help me fix this by recommending an authoring program that allows you to pick which audio track you want or when converting with ConvertX if there is a way to choose which track goes where.
Any help is appreciated thanks and I was not sure which forum to put this in but it seemed like the best.
Load your video into ConvertXtoDVD, then on the main window, expand the tree for your video. You should see a branch for Audio Streams. Expand this, and you can untick the stream you don't want so only the one you do is encoded.
Read my blog here.
I'm not that familiar with ConvertX but that's unlikely.Originally Posted by kurtmaster
Highly unlikely.Originally Posted by kurtmaster
What exactly are you doing in ulead?
ConvertX is already providing you with an authored dvd.
You should just be burning really, at least you've not indicated any re-authoring. If just burning like I say, you're just commiting what convertx spat out to disk.
I don't know Ulead at all but if you are using to re-author then if it's any good at all you should be able to put audio tracks in the oreder you want.
DVD lab.Originally Posted by kurtmaster
I'm pretty sure you can't change track order within convertX
Ogm to Avi, pick of audio track, external subs (batch job)
By 45tripp in forum User guidesReplies: 2Last Post: 10th Jun 2009, 16:53 -
OGM to iPod with alternate audio track
By Salva Veritate in forum Video ConversionReplies: 11Last Post: 13th Feb 2009, 17:09 -
converting OGM/MKV to AVI (with dual audio track)
By mwasim1 in forum Video ConversionReplies: 1Last Post: 4th Jan 2009, 22:54 -
Problem with PCM Audio track when Burning DVD
By darnhs in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 21:07 -
How do I convert .ogm file to .avi and keep a certain audio track?
By Moldiver in forum Video ConversionReplies: 7Last Post: 22nd Jul 2007, 08:43
