Hi,
I recently got a Canopus110, i connect VCR > Canopus > fireware (pc) and i only get black and white video, the audio is fine, i try "everything" every combination of the switches and nothing.. always the same. when i test the video in the TV works great, but with the canopus it's just wrong.
my pc is a celeron 2.66, 1gb ddr400, sata 250,
any help?
i tried different programs and changes on their options, like premiere, vegas, windv, etc.
always the same,
thanks in advance
ps. sorry my 1st post is weird
is the dipswitch on the bottom set to your TV format, PAL or NTSC .
Edit: I just looked and a Google serach tells me Aregentina is NTSC, switch all the dip switches on the bottom to off.
the program you use is irrelevant providing you are capturing as DV-AVI which is what you should be doing. stick with WinDV until you get the problem straightened out.i tried different programs and changes on their options -
Agentina might be NTSC or PAL-N
PAL-N is 625/50 but with PAL color ar a NTSC like 3.58MHz subcarrier.
I'm not sure if the ADVC-110 supports PAL-N.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
thanks u both for reply
Originally Posted by edDV
maybe you're right and it just accept palm what is a shit news to me!,
just to make my mind clear.. im using now VCR > Canopus > PC,
the VCR convert the signal to palN (im from argentina) even if the vhs is ntsc?
do u think/know an external transcorder would help me?
if yes, would i lose quality? (vcr > transcorder > canopus > pc)
thanks again -
Are you sure your VCR will play 525/60 NTSC tapes as 625/50 PAL-N?Originally Posted by mrmoodswing
You should be able to find a VCR that plays NTSC as NTSC. There are also multi-standard VCR's that convert NTSC to PAL. PAL-N is special (or troublesome) in that the luminance is 625/50, the color standard is PAL, but the color subcarrier is at 3.58MHz not 4.43MHz which is normal for PAL. Unless the equipment is designed for PAL-N, it is unlikely to work for color.
Brazil's PAL-M is different again and unique in the world. It uses 525/60 luminance but PAL color with the subcarrier at 3.58MHz. -
yes i understand you, but i have some PALN vhs to convert too.. so i guess canopus wont work with 'me'..
should an external transcorder fix my problem?
thanks! -
Maybe but that would be expensive. The right VCR would be the best solution. One that inputs PAL-N but outputs Euro PAL with subcarrier at 4.43MHz.Originally Posted by mrmoodswing
You could try to email or call Canopus. They may have a PAL-N hack for the ADVC. I'm sure they have heard this over and over from Argentina. -
hahahaha yes, i emailed them few days ago but they didn't answer, i guess i'll have to call him,
thanks a lot man for helping.
Canopus ADVC110 w/Power Director audio stutter problems when capturing?
By popflier in forum Capturing and VCRReplies: 7Last Post: 6th Mar 2010, 04:48 -
Canopus ADVC110 or other converters
By pdx10 in forum Capturing and VCRReplies: 3Last Post: 13th May 2009, 14:35 -
Renting a Canopus ADVC110
By thesmackdown in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2009, 22:34 -
Question about capturing with Canopus ADVC110
By Endzone in forum Capturing and VCRReplies: 8Last Post: 3rd Mar 2008, 21:42 -
Viewing TV using Canopus ADVC110
By cblmdm in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2007, 22:22
