    Apr 2007
    Australia
    ive tried numerous programs to convert this rm file into avi or mpeg but its not working.
    basically i have other avi files that do with the rm file and i use convert x to dvd to convert it all to dvd and it doesnt like the rm file and i cant seem to find any program to fix it.
    its episodes 33, 43, and 44 of samurai pizza cats. i got it off isohunt.com everything else works is just those 3 episodes i cant seem to fix.
    any help would be great.
    thankx
    Dec 2004
    Australia
    Sounds like ConvertXtoDVD is still using libavcodec for decoding. Libavcodec doesn't include a RV30 decoder, only RV10 and RV20.
    Apr 2007
    Australia
    how can i get the codec for convertxtodvd?
    Dec 2004
    Australia
    As I said, I think it uses libavcodec. So you would need to wait for one of the ffmpeg devs to reverse engineer RV30, add support to libavcodec and then wait for VSO to update to the new version.
    You could try AVISynth to frameserve. Gabest's splitter together with Real's decoder should handle it fine.
