After capturing and burning I've noticed that the edges of an object in a movie I created are kind of drifting. It does not matter is it a car or a person, if it moves in a screen it's edges are like a varying, vibrating line (like on the osciloscope). I can not explain it better than this, english is my second language.
When I watch the tape directly from camcorder on a tv it is ok, but if I am capturing on the computer I can see the problem. I tried severaal programs, two different computers, several tapes and no help. Only thing I did not change were camcorder (Panasonic pv-gs150) and fire-wire cable.
Any thoughts about this?
Thank you.
In is called interlacing, it is normal, and you won't see it when you author back to DVD and watch it on your TV.
You see it on your PC because it has a progressive display and makes not attempt to filer for interlacing. Your TV will either be interlaced, or Progressive with hardware filtering. Either way, the best advice is to leave it be. Don't try to remove it, just author as is.Read my blog here.
Probably I was not specific enough.
I would see those problems after I burn a dvd too. I would play a dvd in a dvd player connected to tv and it would be able hard to watch. Only when I hook up the camcorder to tv directly the picture is ok. -
I am not sure that you will be able to see it in this resolution, but here it is.
In this case it is most obvious on the shoulders of approaching man.
piece4.wmv
Hiding a moving object
By akkers in forum EditingReplies: 0Last Post: 29th Nov 2011, 05:59 -
Audio suddenly drifting out of sync
By dubmunkey in forum Software PlayingReplies: 9Last Post: 13th Aug 2010, 07:46 -
Audio drifting out slowly - Gradually goes OOS.
By blackflames in forum AudioReplies: 23Last Post: 10th Jun 2010, 05:02 -
Need help spotlighting object while editing
By eftek in forum EditingReplies: 1Last Post: 19th Mar 2010, 22:54 -
Audio drifting when merging Sony .m2ts files in tsMuxeR
By jaholmes in forum Authoring (Blu-ray)Replies: 2Last Post: 28th Sep 2009, 12:02
