Does anyone know of any plug-ins I can use with Adobe Premiere Pro 1.5 or Adobe Audition to take a stereo mix and turn it into a 5.1 Surround Sound mix?
Do I need software to encode to Dolby Digital 5.1 or will that plug-in do it for me?
It'll create 6 mono WAV files which you can combine with
http://www.rarewares.org/wavewiz/wavewizardv0.54b.zip
and then send to an encoder such as:
http://www.thefrontend.net/EncWAVtoAC3/index.html
However....
Have you tried the scripted "semi-automated" process? It'll save you a lot of work and it sounds really good. No need for VST plugins and multi wav combining.
Requirements:
Install Avisynth
Install .NET 1.1 or Higher (you probably already have it installed)
1) Download This and Unzip
wav_upmixer.zip
2) Save Your 2 Channel (Stereo) WAV file with the name INPUT.WAV and put in same folder. Doubleclick _Run_Upmix.bat to start the process.
3) When it is complete, you'll find the 5.1 AC3 file in the same folder.
Soopafresh, thanks so much for that info!
I'm gonna try out the "semi-automated" process out... -
as you're using audition and V.I. ...
load your stereo source in audition and extract FLFL,CLFE and SLSR using V.I..
in audition multitrack view, "insert",FLFR,CLFE and SLSR.
click Ctrl+E to open the multichannel encoder.
in "panning assignment" adjust:
FL+FR stereo for track 1
Center + LFE stereo for track 2
Ls + Rs stereo for track 3
click export and adjust to export as one interleaved,6-channel wave file and click "OK". now you have one 6-channel wave interleaved!
take this result to EncWav2AC3 to encode your ac3.
Surround Sound in Movies
By therock003 in forum AudioReplies: 36Last Post: 1st Jun 2012, 06:50 -
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
Lg ht 355sd surround sound
By byrnech in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Oct 2011, 06:08 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 12:28 -
Surround Sound Separate
By kwalitykontrol in forum AudioReplies: 1Last Post: 1st Apr 2008, 00:01
