Trying to convert HD-DVD so I can stream on my Media Player.
I've been following a thread on Doom9 which poster managed to get the above working.
Process is
1) Backup HD-DVD to disk (done)
2) Demux files to separate video and audio files
3) Graphedit filters
4) Directshowsource -> Audiodub
5) Windows Media Encoder
The problem is the Backup video (VC-1) file (post Demux) is about 22GB. I can add the filters in GraphEdit but when I add the EVo file, GraphEdit hangs.
Is there a size limitation in GraphEdit?
Well...figured out the problem...I was following instructions to open file....but really need to file ->Render file...then it's no issue...
Just curious - where's that thread on Doom9? I took a quick look in Decyrption and couldn't find it offhand. Some of their threads on HD-DVD are massively big, which makes it hard to find anything.
Originally Posted by jman98
http://forum.doom9.org/showthread.php?t=123010
I've gone through the process and the WMV HD file is 10GB and still growing. I may try to change the filter to DivX HD. I have some DivX HD files and they are about 2.2GBs. I was hoping that the converted WMV/HD file would be smaller.
Still in process so maybe there was an error in the script. -
Thanks! Never thought this kind of subject would be in the Newbies forum as it's kind of advanced.
I want to stream my media but I think this might be a bad idea unless I can find a format that is smaller...onto DivX HD...
WMV to Xvid or Divx
By glenn71x in forum Video ConversionReplies: 3Last Post: 15th Jul 2009, 15:27 -
how to convert wmv to avi for dvd playback[divx support]
By gundja in forum Video ConversionReplies: 4Last Post: 18th Mar 2009, 12:32 -
Converting WMV to burn on DVD to play on DivX
By ez2cy in forum Video ConversionReplies: 30Last Post: 20th Dec 2008, 03:54 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
Converting WMV to divx/xvid
By mattr in forum MacReplies: 1Last Post: 3rd Jan 2008, 09:23
