Installed an AIW a year ago and just now getting around to connecting vid camera to capture. Bought the svideo cable tonight. Tried to capture using native Windows Movie Maker and nothing show on my preview screen/nothing captured. The camera is on and playing tape? What am I missing? Thanks for all who respond... :o
I have ATI All-in-Wonder 9600XT.
Wow, this is only your second post since July 8, 2002?
If your camera is that old and you're now on XP SP2, this might help you:
https://forum.videohelp.com/viewtopic.php?t=304058&highlight= -
He has S-Video from the camcorder not firewire.
Have you installed all the ATI Catalyst and MMC software? Is it functional for the TV tuner and other inputs over the S-Video port? I'd suggest using MMC to capture. VirtualdubMod should also work. -
It's a JVC SuperVHS Digital Image processing camcorder. The TV tuner works but the icon to capture is disabled regardless of the channel.
When I open Studio 8, I start to capture but the preview screen is black (apparently no signal). The same occurs with Windows Movie Maker. Brand new svideo cable plugged into the ATI card along with the two audio cables...
Read the post from p_l indicates I'll never get this camera to work with XP... What the fxxk. -
You may need to reinstall your ATI software. It should be able to record from the tuner.
You could first try another capture program like VirtualdubMod but those will capture uncompressed. You need to use ATI MMC to use the MPeg hardware assist on the AIW card.
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 14:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 11:50 -
downloading a vid from radio-canada.com, but vid isn't available for dwld
By vivimarie in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 12:48 -
Capture video signal from a camera to a laptop
By Cazz in forum Capturing and VCRReplies: 4Last Post: 15th Feb 2009, 16:17 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 23:09
