I can't get any streaming audio to play on my computer and it used to play fine. I even used WMRecorder to download a file on another computer and the problem computer still couldn't play it off of the hard drive. Also, I can't play the audio with most Xvid files on Windows Media Player or RealPlayer. The video plays fine. I checked and I have the codecs. Anyone have any ideas?
Although you may have all of the codecs, most likely some have become corrupt or not properly registered. It is usually best to uninstall any codecs/codec packs using add/remove programs. Then reinstall the codecs as needed. To start with, I would uninstall them, reinstall the latest divx codec, and then try your xvid file.
Google is your Friend -
Thanks for the reply! I already did reinstall the codecs. No change. I did just notice that Divx Player plays the Xvid files perfectly. (Would that be possible if it was a codec problem?) Also, I'm able to play streaming audio in IE if I have AOL open.
Problem convert DVD file to xvid with combine audio channels
By Aquatoid in forum Video ConversionReplies: 5Last Post: 26th Feb 2010, 17:45 -
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 02:49 -
Ripped dvd conversion to xvid/divx weird audio problem
By victoriabears in forum Video ConversionReplies: 1Last Post: 12th Feb 2009, 14:41 -
DVDFab Platinum generic.xvid.mp3 audio problem
By JoeWillis in forum DVD RippingReplies: 0Last Post: 29th Aug 2007, 19:59 -
DVD to AVI[Xvid] Audio Problem
By Kapnos in forum DVD RippingReplies: 14Last Post: 20th May 2007, 01:46
