I recorded WM23. It is nearly 4 hours long. The file after the encode is 14gb. I did it at 9200kbps max and a VBR 1 pass at 100%. What I want to do is let DVD Shrink 3.2 transcode it. How can I get it to load a file and not a DVD structure. I have tried to author it with various programs but I get an error at VOB_9.
I do NOT want to reencode at a lower bitrate. I would rather encode at a higher bitrate and them let a transcoder do the maths at what needs bitrate and what doesnt.
Results 1 to 12 of 12
You might try ReJig to transcode the MPEG file. It works similar to Shrink, but doesn't need the DVD file structure.
You might want to split that file to two DVD discs. Transcoding is not really a great alternative to choosing the proper bitrate in the first place.
It's more useful when you have a slightly oversize file. Four hours of video is unlikely to fit on a DVD without a fair amount of quality loss or re-encoding to a lower bitrate.
You could make up a short representative clip and try a few alternatives, such a transcoding or re-encoding. -
I thik you could get 4 hrs very nicely on a double layer if the bitrate wasn't so high
besides you going to have to author or at least convert to mpeg2 with something because shrink is not going to accept wmv,
AFAIK dvdshrink only accepts DVD files
try avi2dvd, its a GUI front end with avisynth 2.5 famesrever engine and several different encoders all in one pkg
4hr video will likely take an overnight run, as much as 8-10 hrs on high quality settings for a 4hr input file -
I am using a DL disc. But the file is 14gb or so. I dont want to reencode. Would rather just transcode. But looks like I need the file in the DVD structure to do so.Originally Posted by guns1inger
I agree with guns....Re-encode to DL disk.... I'd use DVDRB...
Or as redwudz stated ,split to two disk.. transcoding it will reduce quality no matter what!!! re-encoding it will give you better quality...
JMO!!!!!!" Who needs Google, my wife knows everything" -
"wm23" this is mpeg ? , i wouldn't know, why didn't you just say mpegOriginally Posted by Anakin
At first, I too thought that "wm23" was a codec or something. But a Google search brings up "WrestleMania23", so maybe that's just the program (s)he's trying to convert.
Anakin,
"Transcoding" isn't a magic bullet. It doesn't really do "lossless" conversion. It is ALWAYS lossy, just depends on how much. Also, it usually isn't even as good at recompression (which is what it is really doing) than an additional standard compression/encoding pass would be, it's just often a lot faster, because (the good ones) it just re-Quantizes the same DCT data (by throwing away a little bit more of what it thinks can be ignored).
Simple math will tell you that your 4 hour (14400sec) show which has filesize of 14GB (114688Mb) must have an AVERAGE bitrate of 114688/14400 or 7.96Mbps. 9200kbps is just your MAX during the peaks. BTW, that's Audio+Video, not just video, so video would be lower.
More simple math will tell you that a dual layer disc has ~7.95GB (65126Mb), which means you need your A+V bitrate to be under: 65126/14400=4.52Mbps.
No 2 ways about it, you'll HAVE to reduce your bitrate to fit onto 1 DL disc. Or, if you can't imagine a life without high bitrate wrestlemania, split it to 2 DL discs (2 SL doesn't make much more sense than 1 DL).
Scott -
I am doing it at 352x576 as we speak
Jagabo, please do not reply to this post. Thank you.
Transcode A DivX
By Anakin in forum Video ConversionReplies: 4Last Post: 19th Nov 2008, 07:29 -
Transcode for Dreambox
By dreams in forum Video ConversionReplies: 4Last Post: 13th Oct 2008, 06:50 -
Help - Mass Transcode of DV to ?????
By jmone in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 8th Jun 2008, 21:53 -
Help I can't Transcode AC3 to Anything
By Tyrel919 in forum AudioReplies: 10Last Post: 22nd May 2008, 20:01 -
MPG to h264 w/ATi TransCode Converter 1.01b, audio just won't encode *argh*
By ultradouche in forum Newbie / General discussionsReplies: 2Last Post: 26th Nov 2007, 09:33
