Is this possible? I normally use toast 8 to make PAL DVD for this but there always seems to be a slight pause every second in the movie, any way to make it smooth?
The standard way of converting NTSC film to PAL is simply to speed up the playback of the former. This avoids the trouble you're talking about, at the expense of a ~4% speedup (so pitches are that much higher -- a bit less than a semitone -- and the movies run that much shorter).
How Can I Convert 25FPS 720P To 23.976?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2011, 21:47 -
Convert FLV 25fps to 29.97fps
By Jason77 in forum Video ConversionReplies: 6Last Post: 17th Feb 2011, 16:34 -
canon 5d mkII 30fps to 25fps best way to convert?
By powertase in forum Video ConversionReplies: 3Last Post: 20th Sep 2009, 21:53 -
how to convert a subtitle from 25fps to 23.975fps?
By Ankin in forum SubtitleReplies: 2Last Post: 16th Jun 2008, 15:28 -
Directshowsource forcibily outputs 25fps, 23.98fps source
By rmm21 in forum Video ConversionReplies: 9Last Post: 18th Jul 2007, 06:32
