i have P-4 2.4 with 1gb ram but the Intel mother board don't have a slot for graphic card, i have installed windows vista and i can not use some of the features like 3d flip and dream scean, do i have to change the motherboard for this or i have any other option? if yes which graphic card is good?
please suggest something i am confused![]()
"Diamond X1300 PCI 256MB Viper - Vista-Ready Video Card"
http://www.nforcershq.com/article6809.html
I think the X1300 has recently had its name changed to x1550.
http://www.amazon.com/Diamond-X1550PRO256P-X1550-256MB-GDDR2/dp/B000N5LK7Y -
Thanks for ur reply but i dont think diamond cards are available in india. but can i search for some other brand's pci video card?
Any suggestions?
Is graphic card and video card different in any way? -
Since you don't have an AGP or PCI-Express slot you'll need a PCI based graphics card. There should be something like the X1550 PCI card available to you locally. Don't expect great performance from such a solution though.
Your other choice is to upgrade your motherboard. But the new motherboard will probably require a new CPU and memory as well as the graphics card. You might as well just buy a new computer at that point. -
I have a offer from my hardware dealer he says he can give me a mother board with AGP slot in exchange of my Intel board, is there any way i can check the board if it is no defected?Don't expect great performance from such a solution though.
Also is AGP card better or PCI Express? do they have a big diffrence? i just know that PCI Express is new technology, does that means they are the better one? -
PCI Express has potential to go much faster but early cards aren't that much faster than AGP.
http://en.wikipedia.org/wiki/PCI_Express
http://computer.howstuffworks.com/pci-express.htm
http://en.wikipedia.org/wiki/Accelerated_Graphics_PortRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Most PCI-Express motherboards require DDR2 DRAM. So you'll have to buy new memory too.
If you don't play 3D games a PCI based card will probably be adequate.
Switching to an AGP motherboard and using your DDR memery is the next step up. The only way of checking a motherboard is to install all the components ahd see if it runs. Be aware you'll have to perform a repair reinstall of Windows if you switch motheboards (unless it's the same chipset as your current motherboard).
How To Install A Graphic Card Correctly?
By themaster1 in forum ComputerReplies: 16Last Post: 21st Jan 2010, 23:22 -
Which HDMI interfaced Graphic Card?
By oz_surfer in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2008, 12:56 -
Graphic card ?
By Dash1 in forum ComputerReplies: 7Last Post: 3rd Dec 2007, 12:53 -
Best PC Video Graphic Card for viewing movies on HDTV???
By hulinning in forum DVB / IPTVReplies: 20Last Post: 16th Oct 2007, 06:04 -
CPU and Graphic card
By hanugro in forum ComputerReplies: 8Last Post: 5th Jun 2007, 21:05
