Hey guys i'm new here, comming with a question. I think i put it in the wrong section before, but here is the right one
anyway here is the question:
I am trying to capture video from a TV. When i plug in my recording device and the plugs, it shows as "preview is turned off" and it won't work. For some reason it will not show up on Sony Vegas.
when i try it on studio 10 quickstart, it will record. but i want to use Sony Vegas to record on. why isn't it working?
p.s. i'm using this version of vegas: http://www.sonymediasoftware.com/Products/...uct.asp?PID=977
when i go to the capture image place, it shows what i want to record. but it comes up with this incorrect STI error message. and when i try to exit out of the capture window it breaks down my comp, forcing me to reboot.
IcanslamatornadoRew, since you are new here: You cannot move your own posts. That is considered double posting, and in violation of our rules. PM a Mod if you wish a post moved. I will delete the other post this time.
Also your signature is in violation of our rules:
Please correct this. And read our rules before posting.Signatures
Max 3 lines text using font size 12(bbcode font=Normal) or smaller and using forum width 680 pixels.
Max image size 400x60 and max file size 10kbyte.
Moderator redwudz
Someone should be able to answer your question.
And welcome to our forums.
k thanks man. sorry about those stupid mistakes, i will get right on them. i would just like this question answered is all.
Using HD PVR Capture Module, then placing video in Sony Vegas....
By damonj_3 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 6th Sep 2011, 14:02 -
Can't capture video with Sony Vegas using my HP media center
By fuzzblaster in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2010, 10:45 -
Which format is best to capture and edit from DVD's in Sony Vegas
By fuzzblaster in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2010, 08:38 -
Shouldn't Sony Vegas Pro 8 capture DV avi via firewire?
By brassplyer in forum Capturing and VCRReplies: 6Last Post: 11th Jan 2010, 10:31 -
Sony Vegas Pro 8 Capture in 16.9
By Ben17 in forum Capturing and VCRReplies: 18Last Post: 25th Apr 2008, 02:30
