I've used DVDFab Decrpyter for years and I've never had any problems until today. I was ripping some live music DVDs I had and a message popped up that said something to the effect of - DMA was not enabled and that if it was enabled I would get faster speeds. So, that sounded good and I said yes, enable. The computer needed a restart and then when I went to DVDFab to decrypt after the restart, right when I pressed start, I got the following message:
Task_1 failed! Error=400(20 14)
Process failed
I thought the DVD might be bad so I tried another one. No luck. I tried movies, no luck. I then tried decrypting the original live DVD I started with using DVD Decrpyter (v. 3.5.4.0) and it worked fine. I assume the problem has something to do with enabling DMA. Anyone have any ideas? Below are some specs on my computer
Gateway desktop - Model: GM5260
Windows XP Media Center Edition, SP2
LG Burner - Model: GSA-H11N
DVDFab Decrypter - Version: 3.0.8.6
Results 1 to 1 of 1
DVD Lab Pro 2.20 ERROR. Check inside!
By nick_gr in forum Authoring (DVD)Replies: 3Last Post: 28th Jul 2010, 08:54 -
Problems with DVDFab when converting DVD TV episodes to Xvid
By ryangarfield in forum DVD RippingReplies: 3Last Post: 11th Oct 2009, 10:38 -
DVD (VOB) to AVI Problems Using DVDFab
By BiggerJim in forum DVD RippingReplies: 2Last Post: 27th Feb 2008, 09:45 -
Ratatoullies wont decrypt.
By clownboyz in forum DVD RippingReplies: 26Last Post: 18th Nov 2007, 12:51 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
