hi group:
is it possible to use something simple like dvd2svcd to automatically create one mpeg2 for each chapter on a dvd - this would greatly facilitate making a chaptered (as opposed to a menu) svcd using the ulead software
thanks for your response
sealy
i been thinking about this like a program to cut half the movie into = parts then burning with nero with no time deley between them then giving me chapters if anyone has any ideas on this program or can make 1 go 4 it
Multitracks are not chapters. Even if you set the time to ZERO, there will still be a pause.
http://www.geocities.com/medinotes/vcd/chapters.html
http://www.vcdimager.org/guides/chapters.html (mirror)
The only way of making chapters if with entrypoints.
Regards.Michael Tam
w: Morsels of Evidence -
got it, so now i know what i need to add - entry points. what software is the most ideal and simple to use to create enry points on an svcd ( i have one big mpeg2 file!)? the ulead mm software i use gives me strange errors
thanks,
sealy -
I believe the default settings in DVD2SVCD create chapters corresponding to chapters from the original dvd or you can custom set your own per time (seconds).
Yes...
My particular bias would say that VCDImager is the "best" (most powerful and flexible) program for making chapters on either VCDs or SVCDs.
Regards.Michael Tam
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 11:51 -
VOB to MPEG2 with Chapter Information
By badgerbrian in forum Newbie / General discussionsReplies: 1Last Post: 4th Feb 2008, 14:11
